Controll ORP
anderzon_
Controll ORP
Post by anderzon_ »
Is it possible to control the ozone generator with a ORP expansion to a specific level. Type to shut off if it gets too high and turns on when it gets too low?
butcherman
Re: Controll ORP
Post by butcherman »
Yes. Very easy. I got a thread somewhere if you do a search you will find it. Sorry but im on tapatalk only atm
Sent from my GT-I9500 using Tapatalk
anderzon_
Re: Controll ORP
Post by anderzon_ »
will this code work even if it says further up in the code that port 3 is always on?
    ReefAngel.AddORPExpansion();  // ORP Expansion Module
    ReefAngel.FeedingModePorts = Port6Bit | Port7Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    InternalMemory.OverheatTemp_write( 270 );
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port7 );
    ReefAngel.StandardLights( Port4,17,0,20,0 );
    ReefAngel.Relay.DelayedOn( Port5,5 );
    ReefAngel.StandardHeater( Port6,249,255 );
    ReefAngel.Relay.DelayedOn( Port8,5 );
    if (ReefAngel.Params.ORP>=400)ReefAngel.Relay.Off(Port3);
    if (ReefAngel.Params.ORP>=300)ReefAngel.Relay.On(Port3);
    ReefAngel.DCPump.SetMode( ReefCrest,65,10 );
    ReefAngel.Portal( "anderzon_" );
Re: Controll ORP
Yes, it works.
setup() section only happens once at start up and never again.
But your logic is wrong.
You used >= on both lines.
anderzon_
Re: Controll ORP
Post by anderzon_ »
I see, would this work?
if (ReefAngel.Params.ORP >= 400 ) ReefAngel.Relay.Off(Port3);
if (ReefAngel.Params.ORP <= 300 ) ReefAngel.Relay.On(Port3);
Re: Controll ORP
That works :)
anderzon_
Re: Controll ORP
Post by anderzon_ »
Thank u
If I delete this line from the setup section what would happen then?
Re: Controll ORP
Nothing you would see.
You would probably save a few bytes of code, but nothing noticeable would happen.
Pny
Re: Controll ORP
Post by Pny »
The code you posted here has an undefined region between 300 and 400. The code line in the setup will turn on your ozone unit at power up (power cycle)... If the line is removed I assume it will be off until the Orp level goes down to 300.
200 liter reef cube + 1000 liter FOWLR
