PH calibration
Seedlessone
PH calibration
Is there no way to manually put my ph calibration numbers in anymore? I would like to be able to so I don't have to keep calibrating it every time I want to update something.
Seedlessone
Re: PH calibration
Never mind. I fixed the issue I was having with the client. Is there any other way to do this other than the client?
Re: PH calibration
You can hardcode the numbers:
Or you can use web browser:
http://ipaddress:2000/mi231,840
http://ipaddress:2000/mi233,520
If you use webbrowser, you must reboot the controller
ReefAngel.PHMin=520;
ReefAngel.PHMax=840;
Seedlessone
Re: PH calibration
Bam. That's great. Thanks...
- cosmith71
Re: PH calibration
Silly question...why would you need to change these so often?
lmolenmaker
Re: PH calibration
Hi, can somebody tell me in which section I should insert the code, mentioned in post above?
Thanks in advance.
Leslie
Thanks in advance.
Leslie
rossbryant1956
Re: PH calibration
what are the memory locations for the phe device, the extra ph probe. thx in advance.
Re: PH calibration
For the latest libraries, it is 321 for min and 323 for max.
https://github.com/reefangel/Libraries/ ... als.h#L491
lmolenmaker
Re: PH calibration
is 321 and 323 for ph 7 and ph 10 ?
Leslie
Leslie
