WiFi Alerts Compiling Error
I'm trying to implement lnevo's Wifi alerts and am getting the following compiling errors:
C:\Users\Spencer\Documents\Arduino\libraries\WiFiAlert\WiFiAlert.cpp: In member function 'void WiFiAlert::WiFiSendAlert(char*)':
C:\Users\Spencer\Documents\Arduino\libraries\WiFiAlert\WiFiAlert.cpp:30: error: 'class ReefAngelClass' has no member named 'portalusername'
C:\Users\Spencer\Documents\Arduino\libraries\WiFiAlert\WiFiAlert.cpp:32: error: 'class ReefAngelClass' has no member named 'portalkey'
I thought I added the latest libraries, but something's not working correctly...any suggestions?
Mike
Mike
Re: WiFi Alerts Compiling Error
Check the first or second post in the thread. I should have the wifialert updated there. It should have updates to the RAWiFi class as well
Got it, thanks. Is testing this as simple as pulling the power from the RA unit and waiting for an email?
If you have it setup correctly to send the alert on losing a relay box.
Hey Lee et al,
I'm having the same compile error but I can't find the fix in your other thread. I unzipped the files into the appropriate folders but I'm still getting the compiling error below:
"C:\Program Files (x86)\Reef Angel Controller\libraries\WiFiAlert\WiFiAlert.cpp:32: error: 'class RA_Wifi' has no member named 'portalkey'"
I'm sure I missed something. Please help. Thanks.
Jeremiah
Jeremiah
Yes your missing the updates i posted after 1.1.0 came out.
The good news is that i successfully made a pull request to add this to the libs
Check my thread for the latest link to the new version
Thanks Lee. Trying to find the link now. This is the code I used from your thread (http://forum.reefangel.com/viewtopic.php?f=11&t=2328). Thanks again.
Jeremiah
Jeremiah
Yeah try redownloading the wifialert.zip. It should have 4 files in it...
Still no go. Same compile error. I'm on version 1.1.0
What I did:
Copied latest code from (http://forum.reefangel.com/viewtopic.php?f=11&t=2328) second post.
Grabbed Libraries-master from your github to make sure I have the latest.
Installed WifiAlert/Tide/Moon/Sun into C:\Users\jmaza\Documents\Arduino\libraries
Replaced Reefangel with version from github to C:\Users\jmaza\Documents\Arduino\libraries
Installed WifiAlert/Tide/Moon/Sun into C:\Program Files (x86)\Reef Angel Controller\libraries (did this originally until I realized that I copied into the wrong place).
Added appropriate lines to update/features file
Compiled but still got the same error. (above)
What am I still missing? Thanks again Lee.
Jeremiah
What I did:
Jeremiah
posted before I saw your post. The wifialert.zip I have only has two files:
.cpp
.h
I grabbed that from your github (and the original post). I'll look for the updated version now.
.cpp
.h
Yeah hopefully next version you won't have to do anything
