Simpliest way to switch buttons
wtitb
Post by wtitb »
Hi,
I'm new to this controller, so I hope this is not a silly question. The relay box is used to turn on/off any devices. But if I want to simply switch something like the standby button of my UPS or any other switch, what is the best way for this?
I thought of a 230V relay that is plugged into the relay box, but this seems a bit inconvenient.
cheers,
Christian
Re: Simpliest way to switch buttons
I do something similar with my Eheim auto-feeder. Basically what I'm doing is using a 5V relay connected to an old blackberry charger. When I turn on the outlet for the blackberry charger, it activates the relay which then closes the circuit connected to the manual switch on the eheim feeder. Hope this helps.
jsclownfish
Post by jsclownfish »
I just use one of the ATO ports to trigger my relay. http://forum.reefangel.com/viewtopic.php?f=4&t=1415
-Jon
wtitb
Post by wtitb »
Thanks for your replies!
I could use one of the ATO ports. Do you have a code sample that shows how to turn the relay on/off?
cheers,
Christian
