Dimmable LED Acclimation for corals
Re: Dimmable LED Acclimation for corals
Thats the whole range of internal memory variables used by RA. Look for the pwm ones in the middle somewhere...
ReEfnWrX
So these are all memory locations 258-275 correct?
#define Mem_B_PWMSlopeStart0 VarsStart+58
#define Mem_B_PWMSlopeEnd0 VarsStart+59
#define Mem_B_PWMSlopeDuration0 VarsStart+60
#define Mem_B_PWMSlopeStart1 VarsStart+61
#define Mem_B_PWMSlopeEnd1 VarsStart+62
#define Mem_B_PWMSlopeDuration1 VarsStart+63
#define Mem_B_PWMSlopeStart2 VarsStart+64
#define Mem_B_PWMSlopeEnd2 VarsStart+65
#define Mem_B_PWMSlopeDuration2 VarsStart+66
#define Mem_B_PWMSlopeStart3 VarsStart+67
#define Mem_B_PWMSlopeEnd3 VarsStart+68
#define Mem_B_PWMSlopeDuration3 VarsStart+69
#define Mem_B_PWMSlopeStart4 VarsStart+70
#define Mem_B_PWMSlopeEnd4 VarsStart+71
#define Mem_B_PWMSlopeDuration4 VarsStart+72
#define Mem_B_PWMSlopeStart5 VarsStart+73
#define Mem_B_PWMSlopeEnd5 VarsStart+74
#define Mem_B_PWMSlopeDuration5 VarsStart+75
Exactly.
So the PWMSlopeStart and PWMSlopeEnd are the ones you want. Now if you wanted you could loop through each channel and modify each. Thats one reason why when I had a % of the End % rather than have a min and max dimming hard coded.
If you said 66% instead of 75-25 then regardless of the settings you could change all your dimming independently and still get a consistent acclimation.
ReEfnWrX
True, I guess I just prefer to tell it exactly what I want the beginning Acclimation End% to be. many ways to skin a cat I guess... You have helped me so much already with understanding the code structure that I figured I would just run with my thought process as long as it was ending with the same results and I was doing it right... That way you wouldn't have to do every single step.
Could always create additional bytes for End% for the different channels or your Blue/White/Offwhite etc Channels and have them pull from their respective Expansion channel memory locations with separate formulas.
ReEfnWrX
So I've split the formulas up.
1 for Blue Drivers
1 for White Drivers
More could be added to differentiate between Cool White/Off White - Royal Blue/Cool Blue drivers or UV/Green/Red etc...
1 for Blue Drivers
1 for White Drivers
//Defining different formulas for different channels
// This part would go in your global declarations.
#define Mem_B_AcclDay 100 // 30
#define Mem_B_AcclDuration 101 // 30
#define Mem_B_AcclStartingEndPercent 102 // 25
// The rest of this goes inside your loop() or custom function
// Let's make some variables to work with
byte acclDay = InternalMemory.read(Mem_B_AcclDay); // Let's get what's in memory
byte acclDuration = InternalMemory.read(Mem_B_AcclDuration); //Acclimation Duration
byte acclStartingEndPercent = InternalMemory.read(Mem_B_AcclStartingEndPercent); // Starting End% for Acclimation
byte startPercent = InternalMemory.read(Mem_B_PWMSlopeStart0); // Normal start% 13 //Using Mem_B_PWMSlopeStart0 for all 3 channels
byte endPercentBlue = InternalMemory.read(Mem_B_PWMSlopeEnd1); // Normal Blue end% 65 //Using Mem_B_PWMSlopeEnd1 for both Blue Channels 1,2
byte endPercentWhite = InternalMemory.read(Mem_B_PWMSlopeEnd0); // Normal White end% 75
float acclPercentPerDayBlue = (endPercentBlue-acclStartingEndPercent)/(acclDuration*100); // (65 - 25) / (30 * 100) = 0.013333 = 1.33% increase/day
float acclPercentPerDayWhite = (endPercentWhite-acclStartingEndPercent)/(acclDuration*100); // (75 - 25) / (30 * 100) = 0.016667 = 1.66% incrase/day
// This is how much we're going to alter the dimming
// This number could also be used to adjust the duration
// of the slope... the startPercent, the photoperiod..whatever you want
float acclFactorBlue=acclDay*acclPercentPerDayBlue; // 30 * 0.013333 = .4
float acclFactorWhite=acclDay*acclPercentPerDayWhite; // 30 * 0.016667 = .5
// Adjust the endPercent based on the acclFactor
endPercentBlue=endPercentBlue-(acclFactorBlue*100);
//Here are some samples
// Day 30 = 65 - (0.4 * 100) = 25%
// Day 15 = 65 - (0.199995 * 100) = 45%
// Day 5 = 65 - (0.066665 * 100)= 58%
endPercentWhite=endPercentWhite-(acclFactorWhite*100);
// Here's what some samples look like
// Day 30 = 75 - (0.5 * 100) = 25%
// Day 15 = 75 - (0.25 * 100) = 50%
// Day 5 = 75 - (0.083 * 100) = 67*
ReefAngel.PWM.SetChannel( 0, PWMSlope(13,0,20,30,startPercent,endPercentWhite,40,20) );
ReefAngel.PWM.SetChannel( 1, PWMSlope(12,0,21,30,startPercent,endPercentBlue,40,20) );
ReefAngel.PWM.SetChannel( 2, PWMSlope(12,0,21,30,startPercent,endPercentBlue,40,20) );
// At the end of the day, we need to decrement the acclimation counter.
static boolean acclCounterReady=false; // We need a boolean so we only do this once per day
if (now()%SECS_PER_DAY!=0) acclCounterReady=true; // If it's not midnight we'll get the boolean ready
if (now()%SECS_PER_DAY==0 && acclCounterReady && acclDay>0) { // It's midnight, our bool is true and acclDay is more than 0
acclDay--; // Reduce the counter
acclCounterReady=false; // Reset the boolean flag
InternalMemory.write(Mem_B_AcclDay,acclDay); // Update memory
ReEfnWrX
So out of curiosity I started looking at the values in the memory bank that I am going to pull from out of the globals.h.
By default they are 100... So are these variables that were placed in the memory bank but do not get used unless we call for them?
I was kind of expecting to see my current PWM Channel values there... But then again, I guess that is the difference between using the code and memory option
Mem_B_PWMSlopeEnd0
Mem_B_PWMSlopeEnd1
Default values. The difference between hard coded and memory
ReEfnWrX
So I uploaded the code, and it seems to be still running the standard LED cycle.
Do we need to Create an IF and else if statement?
ReEfnWrX
In my void loop()
I added this
and then in the acclimation code I added
Will this work? or should I move the regular code down into the acclimation code and do an If and else if?
I added this
if ( InternalMemory.read(Mem_B_AcclDay)<=0 );
ReefAngel.PWM.SetChannel( 0, PWMSlope(13,0,20,30,13,55,40,20) ); // Minimum % for Dimming is 11%
ReefAngel.PWM.SetChannel( 1, PWMSlope(12,0,21,30,13,55,40,20) );
ReefAngel.PWM.SetChannel( 2, PWMSlope(12,0,21,30,13,55,40,20) ); // Start Hour, Start Minute, End Hour, End Minute, Start Percentage, End Percentage, Duration, Default Percentage used for lights on mode
}Code: Select all
if (acclDay>0)
ReefAngel.PWM.SetChannel( 0, PWMSlope(13,0,20,30,startPercent,endPercentWhite,60,20) );
ReefAngel.PWM.SetChannel( 1, PWMSlope(12,0,21,30,startPercent,endPercentBlue,90,20) );
ReefAngel.PWM.SetChannel( 2, PWMSlope(12,0,21,30,startPercent,endPercentBlue,90,20) );
ReEfnWrX
Either have the code split between void loop and the custom code.
or
have them all together in the custom code like this
My guess would be it is better to keep them all together. What do you think?
or
if (acclDay=0)
else if (acclDay>0)
No the code works with or without the if because if acclDay is 0 then it should subtract 0 from your normal %.
Either mem is set wrong or you've introduced an error or your old setting is still there. Please post your full code and take out the if.
ReEfnWrX
this is my original code where it went to the normal schedule
I do not know if I am not seeing something, but the way I read it... There is simply two seperate schedules but nothing to tell the RA which to use... so it's defaulting to the first one?
///// ReefAngel.AddPHExpansion(); // pH Expansion Module
ReefAngel.FeedingModePorts = Port3Bit | Port5Bit | Port7Bit;
ReefAngel.WaterChangePorts = Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port4Bit | Port8Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port7 );
//Custom Port Labels
ReefAngel.CustomLabels[0]="Heater";
ReefAngel.CustomLabels[1]="BlueLED";
ReefAngel.CustomLabels[2]="ReturnPump";
ReefAngel.CustomLabels[3]="WhiteLED";
ReefAngel.CustomLabels[4]="KalkATO";
ReefAngel.CustomLabels[5]="Moonlight";
ReefAngel.CustomLabels[6]="WP40";
ReefAngel.CustomLabels[7]="Refugium";
ReefAngel.StandardHeater( Port1,784,790 );
ReefAngel.StandardLights( Port2,12,0,21,30 );
ReefAngel.StandardLights( Port4,13,0,20,30 );
ReefAngel.SingleATO( true,Port5,1200,1 );
ReefAngel.StandardLights( Port8,20,30,13,0 );
/// Using custom code at the bottom ReefAngel.PWM.SetChannel( 0, PWMSlope(13,0,20,30,13,55,40,20) ); // Minimum % for Dimming is 11%
/// Using custom code at the bottom ReefAngel.PWM.SetChannel( 1, PWMSlope(12,0,21,30,13,55,40,20) );
/// Using custom code at the bottom ReefAngel.PWM.SetChannel( 2, PWMSlope(12,0,21,30,13,55,40,20) ); // Start Hour, Start Minute, End Hour, End Minute, Start Percentage, End Percentage, Duration, Default Percentage used for lights on mode
ReefAngel.PWM.SetActinic( ReefCrestMode (0, 0, false));
if ( (hour()>=11) && (now()%SECS_PER_DAY<73800) ) // 11am - 8:30pm
ReefAngel.PWM.SetDaylight( ElseMode(60,20,true) ); // ReefCrest at 55% +/- 20% on sync mode
else if ( (now()%SECS_PER_DAY>73800) && (hour()<23) ) // 8:30pm - 11pm
ReefAngel.PWM.SetDaylight( NutrientTransportMode(0,70,400,true) ); // Nutrient Transport 0%minspeed - 70%maxspeed - 400ms
else if ( (hour()>=23 || hour()<11) ) // 11pm - 11am
ReefAngel.PWM.SetDaylight( ElseMode(30,10, true) ); // ReefCrest at 35% +/- 15% on sync mode
byte acclDuration = InternalMemory.read(Mem_B_AcclDuration); //Acclimation Duration 15
byte acclStartingEndPercent = InternalMemory.read(Mem_B_AcclStartingEndPercent); // Starting End% 55 for Acclimation
byte startPercent = InternalMemory.read(Mem_B_PWMSlopeStart0); // Normal start% 15 //Using Mem_B_PWMSlopeStart0 for all 3 channels
ReefAngel.Portal("ReEfnWrX","******");
static int Delay = random(2000,3000); // Set the initial delay - default 500, 3000
Delay=random(2000,15000); // If so, come up with a new delay - default - 500, 5000
if (WaveSync)
return NewSpeed;
return AntiSpeed;
ReEfnWrX
Never mind, I get it, I didn't think of taking out the original schedule code lol
I updated my previous post with the current fixed code.
- Sacohen
I've been reading along with this, for when I get my LED's.
ReEfnWrX this code, from 2 post up, is the working version?
if (WaveSync)
return NewSpeed;
return AntiSpeed;
ReEfnWrX
No, we have been putting it together for the past few days, I am now testing it.
Seems that it is setting end% at the target%... Trying to figure it out now
When i get it working, I'll post with the separate code sections and where they go in the INO file.
- Sacohen
Thanks.
Please post the final code when you get it working.
ReEfnWrX,
It may also help to lean how to use Serial.print(); and Serial.println(); It may interfere with your wifi while doing it, but after you upload the code, you can open Serial Monitor and see what the variables are doing...
Serial.print("My variable % is: ");
Serial.println(endPercent);
Enjoy, that should help you figure out what's going wrong.
Lee
Lee
ReEfnWrX
Wherever you want it
It will print out whatever output through the serial port to help you debug. So you can set a variable and then print it to verify it's getting set to what you expect.
ReEfnWrX
Ill have to try to figure out how to do it, I am assuming i would use the serial monitor in the coding tool?
lnevo wrote:It may interfere with your wifi while doing it, but after you upload the code, you can open Serial Monitor and see what the variables are doing...
ReEfnWrX
Thanks to the Serial.print I found where the issue was.
Question for you. so I see that acclFactor is being affected by the Controller rounding down formula results that have a decimal... I guess this can be countered by multiplying the decimal by 100 and then dividing that value by 100 in the next formula and +1 so when the formula rounds down we are at the correct full %.
Example
if Percentperday results as a decimal the controller will drop the decimal
2.33*15= 34.95 becomes 2*15 = 30..
and to correct the decimal being dropped
PercentPerday = (75-40)/15)*100=233
acclFactor = (15*(233/100)+1 = 35.95 which the controller will now round down to 35..
Example
Sounds good. You're now an RA professional. Good work
ReEfnWrX
lol far from it.
What is the difference between a float and a byte?
ReEfnWrX
So my previous solution is all fine and dandy if things worked like you thought... lol
apparently
acclPercentPerDay can only be a value between 1-100.....
apparently
It's just the size of the variable:
http://arduino.cc/en/Reference/Float
http://arduino.cc/en/Reference/Byte
ReEfnWrX
So if I wanted to use decimals for the formulas to keep them exact, I should assign all the variables as floats and then my final product end% a byte?
ReEfnWrX
Finally... Code is completed and tested. Everything works. acclDay counter also decays by 1 at midnight.
I will edit my original post for this thread with the final code.
Usually you dont want to do that because floats take up 4-8 times as much mem as a byte...so if you do try and keep it to the variables that need it...ReEfnWrX wrote:So if I wanted to use decimals for the formulas to keep them exact, I should assign all the variables as floats and then my final product end% a byte?
One thing you can do is use casting if you write (float) in front of an equation then it will keep the result as a float. You can use that as a way to placehold the float in your equation without having to declare another float variable.
I do this in my dosing pump calibration function, but I think i also deal with some rounding. It really doesnt make too much of a difference.
Good job though. I'm sure a lot of people will get use out of this. I know I do (although sans dimming..)
