hope you don't mind if I ask before testing, but I want to avoid to damage my RA or other hardware
I use OSRAM ballasts (QTi 1x35/49/80/220-240 DIM) that have a 1-10V interface for dimming. But if I get this right this is realized as a current sink (hope this is the right term in english
When I look at the RA analog dimming, this is also named "1-10V", but here the RA produces the voltage. So I suppose this is not the same interface and connecting the pins could damage something. Am I right and if so, can I use it anyway with some modifications between?
cheers,
Christian
