HW cut off for Skimmer
Seagals
I would like to add a high water cutoff to my skimmate collection tank to prevent overflows. Can someone please verify the following code is correct. I am not a wiz at coding I tried to copy a LW cutoff code given I currently have. but it doesn't seem to be working. My skimmer is on Port 1. I am not sure if its not working because port 1 is on a low water cut off float and thinking maybe I am confusing it?
here's what I did a added a high water cutoff on menu, added menu 7 label, but their is already another label '7' in the color section??, you will see the area I am referring to in all CAPS, also switched lowATO to HIGHATO...is that correct??-
Would someone be able to please review the following high water cut off for me and please lmk where I went wrong?
Thanks in advance.
#include <avr/pgmspace.h>
prog_char menu0_label[] PROGMEM = "Feeding";
prog_char menu1_label[] PROGMEM = "Water Change";
prog_char menu2_label[] PROGMEM = "ATO Clear";
prog_char menu3_label[] PROGMEM = "Overheat Clear";
prog_char menu4_label[] PROGMEM = "PH Calibration";
prog_char menu5_label[] PROGMEM = "Version";
prog_char menu6_label[] PROGMEM = "Clear Low Water";
prog_char menu7_label[] PROGMEM = "Clear Skimmate High Water";
menu0_label, menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label, menu7_label, };
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ReefAngel.ATOClear();
void MenuEntry4()
ReefAngel.OverheatClear();
void MenuEntry5()
ReefAngel.SetupCalibratePH();
void MenuEntry6()
ReefAngel.DisplayVersion();
void MenuEntry7()
ReefAngel.Relay.RelayMaskOff=255;NOT SURE WHAT TO DO HERE DOES THIS NOW BECOME MENUENTRY8- WHAT IS IT FOR???
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit;
ReefAngel.Relay.On( Port1 );//Protien Skimmer
ReefAngel.Relay.On( Port7 );//Chiller
ReefAngel.Relay.On( Port8 );//Main pump
ReefAngel.StandardLights( Port2,9,0,21,30 );
ReefAngel.StandardLights( Port3,11,0,20,30 );
ReefAngel.StandardLights( Port4,9,0,21,30 );
ReefAngel.Wavemaker( Port5,960 );
ReefAngel.PWM.SetDaylight( PWMSlope(11,0,20,25,5,70,120,5) );
ReefAngel.PWM.SetActinic( PWMSlope(9,0,21,30,15,88,60,20) );
static unsigned long lastATOCheck=millis();
ReefAngel.ReverseATOLow();
if (ReefAngel.LowATO.IsActive()) lastATOCheck=millis();
if (ReefAngel.LowATO.IsActive() && (millis()-lastATOCheck>2000)) ReefAngel.Relay.RelayMaskOff&=~(Port8Bit | Port7Bit | Port1Bit);
if ( (hour()>=8 && hour()<20))//wavemakers on at 8am and off at 8pm
static unsigned long nexttoggle=now();
static boolean state=false;
int cycle=nexttoggle-now();
ReefAngel.Relay.Set(Port5,state);
if (cycle<0)
nexttoggle+=random(960,1020);//tunzes on for 15-16 mins
state=!state;
if (cycle<10)//10 sec overlap
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port6);
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.Off(Port6);
ReefAngel.ReverseATOHigh();
if (ReefAngel.HighATO.IsActive()) lastATOCheck=millis();
if (ReefAngel.HighATO.IsActive() && (millis()-lastATOCheck>2000)) ReefAngel.Relay.RelayMaskOff&=~(Port1Bit);
ReefAngel.Portal( "Seagals" );
Thanks in advance.
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
void MenuEntry4()
void MenuEntry5()
void MenuEntry6()
void MenuEntry7()
if (cycle<0)
state=!state;
KRavEN
Re: HW cut off for Skimmer
Could also do a standalone cutoff pretty cheaply. I made mine with an old AC usb charger I tore apart to get 5v DC from 120v AC. Then I hooked that up to one of the cheap single 5v relay boards you can get on ebay and a float switch. Put it all inside some PVC pipe with 2 end caps on each side and some silicone. Total cost less than $5.
Seagals
True, but I bought this controller to eliminate all the diy and wall warts, etc. I would like to expand the use of controller with all the add ons but I just cant grasp the coding aspect of the controller which makes it frustrating.
I tried re coding it and each time I compile I get a different error.
+1 take a look at the CheckSwitches function in my ino for examples
Seagals
Thanks Lee, Nice write up and great stuff but I just don't get coding - I can try to cut and paste your codes into mine but I still don't get coding and don't know if I am doing it right. I have the system working the way I want it and I just wanted to add a high water cut off code to existing code to prevent a potential problem.
Seagals
I found a simple code on the site if any one needs it:
ReefAngel.Relay.Off(Port2);
ReefAngel.Relay.On(Port2);
That's what I use too
In addition, I set HighATO trigger in the portal to send me an email notification.
Naptalene
+1
Reefology
How do you set this trigger?rimai wrote:That's what I use too
Just choose ATO High equals 1 or 0 depending on how you orient the float.
Reefology
Did you wait at least 5 minutes to enable the controller to send data.
The controller only sends data to the portal every 5 minutes.
Reefology
i did at least15 mins each attempt, thats not the issue. any other ideas?
Reefology
still nothing?!
does =1 mean ATO high is active? because my skimmer shuts down and ato high status light changes to green.
Reefology
now i'm not getting any email notifications? Can I please get some help with this?
what's funny is the portal notifications show the last time triggered but no email was sent?
thanks
thanks
I am checking the mailbox that sends the emails and I do see emails sent to you, including the ATO High Port = 0.
The last alert was sent about 3 days ago of having pH lower than what you had set.
Reefology
thanks for looking into this for me Roberto. I have been testing multiple triggers everyday for the past week and did get the two messages you mentioned. problem is those are the only 2 I received.
That ATO High Port =0 triggered every hour for 4 days before I got the email, I have no idea why it took so long to send the email? I have since deleted it.
The ph trigger was raised to < 8.2 in order to have it trigger each day.
