Orp expantion not working
butcherman
Post by butcherman »
How would it test if the orp expansion is working. It use to work fine. Then just stopped working. I get 0 reading from the orp. Even if I try calibrate it and use the terminator. Im using the ra+ no other add ons.
butcherman
Re: Orp expantion not working
Any ideas.
Sent from my GT-I9500 using Tapatalk
Is the led on the side turned on?
Try another 12vdc power supply
butcherman
yup green led is showing, I have tested another 12v dc and another orp probe both with no luck. Is there any way to determine if the orp unit itself is giving out any outputs?
You may need to send it back for analysis.
PM for RMA.
butcherman
I will try test the unit on a friends ra. If no luck we can look at analysis I think
