Wifi Error
deputy1234
Wifi Error
Post by deputy1234 »
Hi,
I have having trouble setting up my wifi.
I am able to connect to to the wifi attachment using wifi utility. However when trying to set up wifi attachment in wifi utility, I always get an error message.
Can some help?
Re: Wifi Error
Did you choose the correct serial port?
Is the wifi attachment plugged into the usb cable properly, with the black wire to the right?
Is the module blinking green and blue?
deputy1234
Re: Wifi Error
rimai wrote:diid you choose the correct serial port?
There is only one opion to select. COM 4
Yes,. the wire is connected correctly.
Yes both blue and green ( looks a alittle yellow) are blinking quickly.
Re: Wifi Error
Can you paste the entire log?
Click the button "Copy to Clipboard"
deputy1234
Re: Wifi Error
rimai wrote:Can you paste the entire log?
Opening Serial Port...
Verifying speed at 9600 baud
Connected to serial port COM4
< CMD
> set u b 57600
< set u b 57600
< AOK
< <4.41>
> set s p 0
> save
> reboot
Verifying speed at 57600 baud
Removing connection to COM4
< CMD
> reboot
< reboot
Wifi Attachment Connected to COM4
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 2 86328 3 wifly-GSX-400
< 4 74920 3 web_app-GSX-106
< 7 46632 3 wps_app-GSX-131
< 9 66240 3 eap_app-GSX-101
< 11 37282 0 web_config.html
< 21 512 0 link.html
< 24 1052 10 config
< 25 944 10 user
< 26 88548 3 wifly-GSX-441-r1057
< 145 Free, Boot=26, Backup=2
< <4.41>
> load user
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
> set o d ReefAngelWifi
< set o d ReefAngelWifi
< AOK
< <4.41>
> set w l 5
< set w l 5
< AOK
< <4.41>
> set w s Dhouse
< set w s Dhouse
< AOK
< <4.41>
> set w p ********
< set w p ********
< AOK
< <4.41>
< AOK
< <4.41>
< AOK
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
> reboot
< reboot
Re: Wifi Error
Where did you get that module?
deputy1234
Re: Wifi Error
rimai wrote:Where did you get that module?
I ordered the controller and wifi on January 16, 2014
Re: Wifi Error
That's so weird....
There was no module sold with that firmware 4.41
Did you update yourself?
Try factory reset and do it again.
deputy1234
Re: Wifi Error
rimai wrote:That's so weird....
how would I factory reset?
Yes I did try to update. Could this be the problem?
deputy1234
Re: Wifi Error
I tried doing a factory rest using the wifi Utility but was no luck. Still got the error message.
Re: Wifi Error
Can you paste the log of the factory reset?
deputy1234
Re: Wifi Error
rimai wrote:Can you paste the log of the factory reset?
< CMD
> set u b 57600
< set u b 57600
< AOK
< <4.41>
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 24 1052 10 config
< 25 944 10 user
< <4.41>
> load user
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
< AOK
< <4.41>
> set w l 5
< set w l 5
< AOK
< <4.41>
> set w s Dhouse
< set w s Dhouse
< AOK
< <4.41>
> set w p 5198545981
< set w p 5198545981
< AOK
< <4.41>
< AOK
< <4.41>
< AOK
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
> reboot
< reboot
< CMD
> set u b 57600
< set u b 57600
< AOK
< <4.41>
> set s p 0
> save
< <4.41>
> reboot
< CMD
> reboot
< reboot
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 24 1052 10 config
< 25 944 10 user
< <4.41>
> load user
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
< AOK
< <4.41>
> set w l 5
< set w l 5
< AOK
< <4.41>
> set w s Dhouse
< set w s Dhouse
< AOK
< <4.41>
> set w p 5198545981
< AOK
< <4.41>
< AOK
< <4.41>
< AOK
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
> reboot
< reboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> factory RESET
< factory RESET
< Set Factory Defaults
> reboot
< <4.41>
< reboot
Factory Settings Restored
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 24 1052 10 config
< 25 944 10 user
< <4.41>
> load user
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
< AOK
< <4.41>
> set w l 5
< set w l 5
< AOK
< <4.41>
> set w s Dhouse
< set w s Dhouse
< AOK
< <4.41>
> set w p 5198545981
< AOK
< <4.41>
< AOK
< <4.41>
< AOK
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
> reboot
< reboot
< CMD
> set u b 57600
< set u b 57600
< AOK
< <4.41>
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> factory RESET
< factory RESET
> reboot
< <4.41>
< reboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 24 1052 10 config
< 25 944 10 user
< <4.41>
> load user
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
< AOK
< <4.41>
> set w l 5
< set w l 5
< AOK
< <4.41>
> set w s Dhouse
< set w s Dhouse
< AOK
< <4.41>
> set w p 5198545981
< AOK
< <4.41>
< AOK
< <4.41>
< AOK
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
> reboot
< reboot
< CMD
> set u b 57600
< set u b 57600
< AOK
< <4.41>
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 24 1052 10 config
< 25 944 10 user
< <4.41>
> load user
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
< AOK
< <4.41>
> set w l 5
< set w l 5
< AOK
< <4.41>
> set w s Dhouse
< set w s Dhouse
< AOK
< <4.41>
> set w p 5198545981
< AOK
< <4.41>
< AOK
< <4.41>
< AOK
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
> reboot
< reboot
< CMD
> set u b 57600
< set u b 57600
< AOK
< <4.41>
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 24 1052 10 config
< 25 944 10 user
< <4.41>
> load user
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
< AOK
< <4.41>
> set w l 5
< set w l 5
< AOK
< <4.41>
> set w s Dhouse
< set w s Dhouse
< AOK
< <4.41>
> set w p 5198545981
< AOK
< <4.41>
< AOK
< <4.41>
< AOK
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
> reboot
< reboot
< CMD
> set u b 57600
< set u b 57600
< AOK
< <4.41>
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> factory RESET
< factory RESET
> reboot
< <4.41>
< reboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 24 1052 10 config
< 25 944 10 user
< <4.41>
> load user
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
< AOK
< <4.41>
> set w l 5
< set w l 5
< AOK
< <4.41>
> set w s Dhouse
< set w s Dhouse
< AOK
< <4.41>
> set w p 5198545981
< AOK
< <4.41>
< AOK
< <4.41>
< AOK
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
> reboot
< reboot
< CMD
> set u b 57600
< set u b 57600
< AOK
< <4.41>
> set s p 0
> save
< <4.41>
> reboot
< CMD
> reboot
< reboot
< CMD
> factory RESET
< factory RESET
> reboot
< <4.41>
< reboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> set u b 57600
< set u b 57600
< AOK
< <4.41>
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 24 1052 10 config
< 25 944 10 user
< <4.41>
> load user
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
< AOK
< <4.41>
> set w l 5
< set w l 5
< AOK
< <4.41>
> set w s Dhouse
< set w s Dhouse
< AOK
< <4.41>
> set w p 5198545981
< AOK
< <4.41>
< AOK
< <4.41>
< AOK
< <4.41>
> save
< save
< Storing in config
< *BAD CONFIG*
< <4.41>
> reboot
< reboot
< CMD
> set u b 57600
< set u b 57600
< AOK
< <4.41>
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> factory RESET
< factory RESET
> reboot
< <4.41>
< reboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> factory RESET
< factory RESET
> reboot
< <4.41>
< reboot
Re: Wifi Error
How did you update the firmware?
deputy1234
Re: Wifi Error
rimai wrote:How did you update the firmware?
I updated the firmware through wifi Utility but received the error message ** ERROR - Please disconnect and then reconnect the Reef Angel Wifi Attachment from the USB-TTL cable and try again.
Re: Wifi Error
Are you sure that you are using the correct SSID and passphrase? They are case sensitive, so uppercase and lowercase matters.
The update firmware button is not working.
What's making me confused is the fact that in order to update firmware, you must be connected to wifi in the first place. So, even if the button was working, there would be no way to download new firmware.
Unless you had it connected. Was the unit ever connected to the internet before?
Did you ever connect to the module using teraterm or putty?
I think we need to wipe out the config file and start from scratch.
I need to update one of my units to see how to do that.
deputy1234
Re: Wifi Error
rimai wrote:Are you sure that you are using the correct SSID and passphrase? They are case sensitive, so uppercase and lowercase matters.
Yes the SSID and passphrase are correct.
I did have the wifi connected and then tried to update but received the error message.
I was able connect to teraterm. I tried it last nigh to factory reset but I was not sure how to.
Re: Wifi Error
Ok, I was able to replicate the issue and it was definitely due to the firmware upgrade.
Let's try this:
You need to decompress the zip file.
Open the .ttl file in notepad or any other text editor.
Change the SSID and passphrase.
Save the file.
Use Tera Term and go to menu Control->Macro
Browse to the .ttl file you just edited.
It should configure the module at the end of the process.
If you don't get anything in the screen, you will need to change the baud rate before you open the .ttl file.
Go to menu Setup->Serial port and choose 57600 baud and then go to menu Control->Macro to open the .ttl file.
If that does not work for some reason, copy and paste what you get on the screen.
wifi attachment no ftp.zip
(664 Bytes) Downloaded 777 times
deputy1234
Re: Wifi Error
rimai wrote:Ok, I was able to replicate the issue and it was definitely due to the firmware upgrade.
Let's try this:
Save the file.
Thank you for all your help Roberto!!! it's working!
Drew471
Re: Wifi Error
Post by Drew471 »
Ok I am going to play the noob here. Do you need to setup using the wifi utility first or will this due the setup as well (so I should do the factory reset) . I follow the directions and I get a green blinking light meaning ip a dress ok.... What does that mean?
Sent from my SPH-L720 using Tapatalk
Re: Wifi Error
It means you are good to go.
Don't update the firmware as it will cause you to have problems mentioned in this thread.
AquaO
Re: Wifi Error
Post by AquaO »
I have the same issue...
I tried to update firmware today and have exactly the same problem. My wifi works well for a year. I thought to do well when I make this "update" ;)
I will tried that is mentioned in this post...
Thank
Osaka 40g with 55g sump
Radion, 2X Tunze 6045, Swc-160 mini cone
AquaO
Re: Wifi Error
Post by AquaO »
It's back to work :D
Thank for this thread!!
JDP1130
Re: Wifi Error
Post by JDP1130 »
looks like i have same issue and i am unable to use this wor work correctly. seems as though i cannot get code to push to wifi attachment.
Re: Wifi Error
Did you update the firmware?
Is the module blinking blue and green?
Can you paste the log from the wifi utility?
ahmed
Re: Wifi Error
Post by ahmed »
i have same issue any idea?
Ferdi
Re: Wifi Error
Post by Ferdi »
Hi all, hope everyone is doing well. Im experiencing the same thing as everyone experienced back in 2012.
I followed all the steps in the thread with the file attached and it still doesn’t want to work.
I did change it ip,ssid and password to mine but still no luck.
Maybe there is a small simple thing im doing wrong that I can’t pick up.
Can i perhaps paste the code here and maybe someone might pick up what im totally missing?
Re: Wifi Error
Can you post the log of what you get on tera term?
Ferdi
Re: Wifi Error
Post by Ferdi »
There is no log.
A small window pops up for confirmation and shows that its running but after a while it asks again to configure and so it goes on the whole time
Re: Wifi Error
Your cable may be bad then
