Wp25 quit
chapboogie
Wp25 quit
Post by chapboogie »
One of my 25's quit. This one has only been in my tank Since November. My other one had been running since May. I cleaned it, even soaked it over night. Still not working. The impeller engages and sometimes a quick spin, but won't keep going.
Any suggestions? Is my pump shot? If so, is there a place to just get the pump cheap. I bought these in a group buy.
Sent from my SCH-I535 using Tapatalk
Re: Wp25 quit
Try switching the power supply with your other one. It may not be the pump itself.
chapboogie
Re: Wp25 quit
Still not working
Re: Wp25 quit
:) Sorry man
Re: Wp25 quit
Be glad its not a $300 mp10. You can get replacement parts from fish street i believe
chapboogie
Re: Wp25 quit
So after letting it dry for a few hours, I plugged it in and it worked. It seemed a bit weak. I put it in the water and a minute later it quit. Hmmmm
KRavEN
Re: Wp25 quit
Post by KRavEN »
I had a similar thing happen with a WP40 that I was temporarily running with reduced voltage instead of the full 24v. Were you supplying less than 24v or using one of those dimmers to reduce the voltage?
chapboogie
Re: Wp25 quit
I'm using the reef angel cable
chapboogie
Re: Wp25 quit
KRavEN wrote:I had a similar thing happen with a WP40 that I was temporarily running with reduced voltage instead of the full 24v. Were you supplying less than 24v or using one of those dimmers to reduce the voltage?
Did yours come back?
KRavEN
Re: Wp25 quit
Post by KRavEN »
nope, what voltage power supply were you using?
chapboogie
Re: Wp25 quit
The one that comes with
Piper
Re: Wp25 quit
Post by Piper »
I'm a little late on this but, if you haven't already done so, try re-seating the impeller. I had one of two new 25s do that to me as well after about a week of use. After 3 or 4 times of re-seating the impeller it's bee working fine since. That was about 3 months ago.
~Charlie
