WIFI set up issue
Marvollo
WIFI set up issue
Post by Marvollo »
I have wifi set up for a month or so and it worked well. Then i had to reset my router and it stopped working. I tried to use the wifi set up utility but if shows all false information and an incorrect ip address. I have been trying to research this all morning but I am overwhelmed, I am new to all of this. I don't know if a firmware update went through at some point. I reset it back to factory several times as well.
Opening Serial Port...
Verifying speed at 9600 baud
Connected to serial port /dev/tty.usbserial-AH01Q8U5
> set u b 57600
> set s p 0
> save
> reboot
Verifying speed at 57600 baud
Removing connection to /dev/tty.usbserial-AH01Q8U5
< CMD
> reboot
< reboot
Wifi Attachment Connected to /dev/tty.usbserial-AH01Q8U5
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 2 86328 3 wifly-GSX-400
< 4 74920 3 web_app-GSX-106
< 7 46632 3 wps_app-GSX-131
< 9 66240 3 eap_app-GSX-101
< 11 37282 0 web_config.html
< 21 512 0 link.html
< 24 -1 10 config
< 25 -1 10 user
< 168 Free, Boot=2, Backup=2
< <4.00>
> load user
< load user
< AOK
< <4.00>
> save
< save
< Storing in config
< <4.00>
> save
< save
< Storing in config
< <4.00>
> set o d ReefAngelWifi
< set o d ReefAngelWifi
< AOK
< <4.00>
> set w l 5
< set w l 5
< AOK
< <4.00>
> set w s newjerolly
< set w s newjerolly
< AOK
< <4.00>
> set w p changedforprivacy
< set w p changedforprivacy
< AOK
< <4.00>
< AOK
< <4.00>
< set ftp address 198.175.253.161
< AOK
< <4.00>
> save
< save
< Storing in config
< <4.00>
> reboot
< reboot
< CMD
< Disconn from newjerolly,AUTH-ERR
< Auto-Assoc newjerolly chan=4 mode=MIXED SCAN OK
< Joining newjerolly now..
> show n
< show n
< SSid=newjerolly
< Chan=4
< Assoc=FAIL
< Rate=12, 24Mb
< Auth=FAIL
< Mode=MIXED
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=0
< <4.00>
> get i
< get i
< IF=DOWN
< DHCP=ON
< IP=1.2.3.4:2000
< NM=255.255.255.0
< GW=1.2.3.4
< HOST=198.171.134.6:80
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.00>
> reboot
< reboot
Found router N300 Wireless Router
Port 2000 is now being forwarded to 1.2.3.4
< CMD
> ftp u
< ftp u
< <4.00>
< FTP connecting to 198.175.253.161
< FTP timeout=2
** ERROR - Please disconnect and then reconnect the Reef Angel Wifi Attachment from the USB-TTL cable and try again.
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ftp u
< ftp u
< <4.00>
< FTP timeout=2
> set u b 57600
> set s p 0
> save
> reboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 24 -1 10 config
< 25 -1 10 user
< <4.00>
> load user
< load user
< AOK
< <4.00>
> save
< save
< Storing in config
< <4.00>
> save
< save
< Storing in config
< <4.00>
< AOK
< <4.00>
> set w l 5
< set w l 5
< AOK
< <4.00>
> set w s newjerolly
< AOK
< <4.00>
< AOK
< <4.00>
< AOK
< <4.00>
< AOK
< <4.00>
> save
< save
< Storing in config
< <4.00>
> reboot
< reboot
< CMD
> show n
< show n
< SSid=newjerolly
< Chan=4
< Assoc=FAIL
< Rate=12, 24Mb
< Auth=FAIL
< Mode=MIXED
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=0
< <4.00>
> get i
< get i
< IF=DOWN
< DHCP=ON
< IP=1.2.3.4:2000
< NM=255.255.255.0
< GW=1.2.3.4
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.00>
> reboot
< reboot
< CMD
> factory RESET
< factory RESET
< Set Factory Defaults
> reboot
< <4.00>
< reboot
Factory Settings Restored
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 24 -1 10 config
< 25 -1 10 user
< <4.00>
> load user
< load user
< AOK
< <4.00>
> save
< save
< Storing in config
< <4.00>
> save
< save
< Storing in config
< <4.00>
< AOK
< <4.00>
> set w l 5
< set w l 5
< AOK
< <4.00>
> set w s newjerolly
< AOK
< <4.00>
< AOK
< <4.00>
< AOK
< <4.00>
< AOK
< <4.00>
> save
< save
< Storing in config
< <4.00>
> reboot
< reboot
< CMD
> show n
< show n
< SSid=newjerolly
< Chan=4
< Assoc=FAIL
< Rate=12, 24Mb
< Auth=FAIL
< Mode=MIXED
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=0
< <4.00>
> get i
< get i
< IF=DOWN
< DHCP=ON
< IP=1.2.3.4:2000
< NM=255.255.255.0
< GW=1.2.3.4
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.00>
> reboot
< reboot
Re: WIFI set up issue
Don't update the firmware.
You are fine the way it is.
I'm thinking that you may be typing either the SSID or pass wrong.
They are case sensitive.
Can you double check?
Marvollo
Post by Marvollo »
password and said are correct
Did you change the router or simply restarted?
Have you changed the security scheme of the router?
Marvollo
Post by Marvollo »
I have restarted my router and modem several times. The only changes I have made are adding virtual servers for gaming. all of my other devices have connected to my wifi without any issues.
Marvollo
Post by Marvollo »
any word? I even went back and reinstalled the wifi utility and the same is showing. false everything and not my router nor my ip address
If the SSID and Pass are correct, the only other thing that would cause authentication errors is the security of your router.
Make sure you have WPA2-Personal with AES encryption.
Marvollo
Post by Marvollo »
i do and the ssid and password are correct. it is on wpa2-personal with ads.
Marvollo
Post by Marvollo »
Rimai, Yes to the pm connection. I replied via iphone and it doesn't show in my sent messages.
It doesnt go to sent till it's read
