Internal memory ATO using Multi-Channel Water Level
Ask in here.
smellsfishy
Post by smellsfishy »
Hey all, I've got a RA+ with the Mult-Channel Water level expansion. I'm trying to switch everything over to internal memory but running into a problem where it seems that, by default, the RA Wizard assumes that channel 0 is the one to watch for the water level. The problem is that it should be looking at channel 1. There's nothing in the .ino that I seem to be able to change, and I looked at the ATO section in the portal to see if I could specify it there but no go. Is this possible to do in memory?
smellsfishy
Re: Internal memory ATO using Multi-Channel Water Level
uhoh, I hope its not due to github issue 138? how far away is this feature from being implemented?
Correct.
We don't have it implemented yet.
It will be in the next release though.
