Hi Guys,
i'm writing because of a strange issue who's happening since a couple of months.
My temperature probe sometimes goes crazy... i can read 85°C (i think 185°F) for some seconds and then it comes back to normal.
Unfortunately this activates the overheat flag and locks lights and heater.
I've tryed to disconnect the second temp probe and ph probe without success....
Any suggestions?
Temperature probe and overheat issue
Re: Temperature probe and overheat issue
i've also tryed to change the probe and use the other one i have (who's used as room temp) but same problem occours...
yesterday evening i've tryed to swap the room probe with the water one and resetting the controller....
let's look if it works...
after some days with the new proble no issues at the moment.... seems that problem is solved...
