ATO COde
Ask in here.
ecam
ATO COde
Post by ecam »
I am trying to get my ATO setup and the code is not working from the reef angel wizard. how can i get it to trigger properly?
        byte myRFMode=0;
        byte myRFDuration=0;
        byte myRFSpeed=0;
        // Ports toggled
      ReefAngel.WaterChangePorts = Port3Bit | Port7Bit| Port8Bit| Box1_Port1| Box1_Port4| Box1_Port6; // Turn off Return, UV, Skimmer, Heater, Sump Equipment, ATO
      ReefAngel.FeedingModePorts = Port3Bit | Port8Bit; // Turn off Return and Skimmer
      ReefAngel.LightsOnPorts = Port2Bit | Box1_Port2;  //Turn on ATI lights, Fan and Fuge Light
      ReefAngel.OverheatShutoffPorts = Port4Bit |Box1_Port1; // ATI Lights and Heaters
                InternalMemory.OverheatTemp_write( 825 );   // Set the Overheat temperature setting
           //Box1
           ReefAngel.Relay.Off(Port1);                        //  Port1 Acropower Dosing ...
           ReefAngel.Relay.Off(Port2);                        //  Port2 Fuge Light
                    if (hour()>=23 && hour()<7) ReefAngel.Relay.On(Port2);     // Fuge Between 11pm-7am turn the relay on
           ReefAngel.Relay.On(Port3);                         //  Port3 Return Pump -- Always on
           ReefAngel.Relay.Off(Port4);                        //  Port4 Not Used
           ReefAngel.Relay.Off(Port5);                        //  Port5 Not Used
           ReefAngel.Relay.Off(Port6);                        //  Port6 Not Used
           ReefAngel.Relay.On(Port7);                         //  Port7 UV Lamp -- Always on
           ReefAngel.Relay.DelayedOn( Port8,5 );              //  Port8 Skimmer -- 5 min delay start
          //box 2 (Box1_Portxx)
          ReefAngel.StandardHeater( Box1_Port1,778,790 );     //  Box1_Port1 Heater
          ReefAngel.Relay.On(Box1_Port2);                     //  Box1_Port2 Razor_LED (Sump) -- Always on
          ReefAngel.Relay.Off(Box1_Port3);                    //  Box1_Port3 Not Used
          ReefAngel.Relay.On(Box1_Port4);                     //  Box1_Port4 Sump Equipment-- Always on
          ReefAngel.Relay.On(Box1_Port5);                     //  Box1_Port5 MP40s -- Always on
         // ReefAngel.Relay.Off(Box1_Port6);                  //  Box1_Port6 ATO Top off (RODI)
            ReefAngel.SingleATO(true,Box1_Port6,60,0); // ATO Low port with 60 seconds timeout
         // ReefAngel.SingleATOHigh(true,Box1_Port6,300,0);         // ATO Low port with 5 min timeout (200 mls per min, 3,785mls in a gallon)
          ReefAngel.Relay.Off( Box1_Port7);                   // Box1_Port7 ALK Doser
          ReefAngel.Relay.Off( Box1_Port8);                   // Box1_Port8 Calc Doser
                          // Old Code
                              //moonlight dimming
                                     //    if (hour()>=6 && hour()<10) ReefAngel.PWM.SetDaylight( PWMParabola(6,0,10,0,9,100,9) ); // Moonlight Between 5-10am turn the relay on
                                     //    if (hour()>=20 && hour()<=23) ReefAngel.PWM.SetDaylight( PWMParabola(20,0,23,0,100,0,100) ); // From 8pm-Midnight turn the relay on
                                     //    else ReefAngel.PWM.SetDaylight(0);
                                     //  ReefAngel.Relay.Set( Port2, !ReefAngel.Relay.Status( Port4 ) ); //Refuge opposite of Actinic
                                     //  ReefAngel.Relay.Off( Box1_Port3); // Start with the relay off       Port #11 Moonlight
                                        //if (hour()>=5 && hour()<10) ReefAngel.Relay.On(Box1_Port3); // Moonlight Between 5-10am turn the relay on
                                        //if (hour()>=20 && hour()<=23) ReefAngel.Relay.On(Box1_Port3); // From 8pm-Midnight turn the relay
                                     //    ReefAngel.PWM.SetDaylight( PWMSlope(20,0,23,0,100,0,180,100) );
                                     //   ReefAngel.PWM.SetDaylight( PWMSlope(6,0,10,0,9,100,240,9) );
                                     //ReefAngel.Relay.off(Box1_Port3);
                                     //  if (hour()>=10 || hour()<20) ReefAngel.PWM.SetDaylight(0);
                                     //    ReefAngel.PWM.SetDaylight( MoonPhase()+10 );
                                    // ReefAngel.PWM.SetDaylight(PWMParabola(20,0,23,0,0, MoonPhase(),0 ));
                                    //ReefAngel.PWM.SetDaylight(PWMSlope(6,0,23,0,0,100,240,0));
                                    //if (hour()>=5 && hour()<20) ReefAngel.PWM.SetDaylight(0);
                                    //ReefAngel.PWM.SetDaylight( PWMParabola(20,0,23,0,100,0,100) );
                                    //ReefAngel.PWM.SetDaylight( PWMParabola(6,0,10,0,9,100,9) );
          if (hour()>=6 && hour()<11)
            myRFSetMode(ReefCrest,85,10);
          else if (hour()>=11 && hour()<13)
          else if (hour()>=13 && hour()<16)
            myRFSetMode(Smart_NTM,85,50);
          else if (hour()>=16 && hour()<19)
            myRFSetMode(ReefCrest,65,10);
            myRFSetMode(Lagoon,40,10);
        // Hardcode PH calibrations
         //ReefAngel.PHMin=544; // PH7.0
         //ReefAngel.PHMax=830; // PH10.0
         RunDosingPumps();
         LogDosingPumps();
        ReefAngel.Portal( "ecam" );
        ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params,
        ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params );
              strcat(text,"  ");
              ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,15,93,"Salinity:");
              ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,75,93,text);
    // Define Your dosing pumps
    #define numDPumps 4
    byte pumpRelays[numDPumps]={ Box1_Port7, Box1_Port8,Port1Bit,Box1_Port6 };
    int DPVolume[numDPumps]={ 17, 17, 7} ; // 1ml for each alk and calcium - total volume for the day
    int DPRepeat[numDPumps]={ 360, 360, 360 } ; // Repeat every 4 hrs 6x a day --- in mins
    // Define Calibration here
    int CalTime[numDPumps]={ 600, 600, 600,600 }; // 10 minutes / 10 minutes
    int CalVol[numDPumps]={ 350, 300,384,120000 }; // 350ml / 300ml... .58 / .5/.64
    // Function: RunDosingPumps()
    void RunDosingPumps() {
      float rate;
      int calcTime[numDPumps];
      for (int i=0;i < numDPumps; i++) {
        rate=(float)CalVol[i]/CalTime[i];
        calcTime[i]=DPVolume[i]/rate/(1440/DPRepeat[i]);
        // Run the pumps
        ReefAngel.DosingPumpRepeat(pumpRelays[i], i*5, DPRepeat[i], calcTime[i]); // Offset between each pump is 5 minutes
      // Display Time calculated in portal
      ReefAngel.CustomVar[0]=calcTime[0];
      ReefAngel.CustomVar[1]=calcTime[1];
      ReefAngel.CustomVar[2]=calcTime[2];
      ReefAngel.CustomVar[3]=calcTime[3];
    // Function: LogDosingPumps()
    void LogDosingPumps() {
      static time_t pumpTimer[numDPumps];
      static boolean pumpStatus[numDPumps];
      float rate;
      for (int i=0;i< numDPumps;i++) {
        if (ReefAngel.Relay.Status(pumpRelays[i])) {
          if (!pumpStatus[i]) {
            pumpStatus[i]=true;
        } else {
          if (pumpStatus[i]) {
            pumpStatus[i]=false;
            // Report How much volume has been dosed per day.
            // Could make this in minutes... excercise for the reader..
            ReefAngel.CustomVar[3]=pumpTimer[0]*rate;
            ReefAngel.CustomVar[4]=pumpTimer[1]*rate;
            ReefAngel.CustomVar[5]=pumpTimer[2]*rate;
        // Clear timer at end of day
        if (now()%SECS_PER_DAY==SECS_PER_DAY-1) pumpTimer[i]=0;
        void myRFSetMode(byte m, byte s, byte d)
          if (m!=myRFMode || s!=myRFSpeed || d!=myRFDuration || millis()<5000)
            myRFMode=m;
            myRFSpeed=s;
            myRFDuration=d;
            ReefAngel.RF.SetMode(m,s,d);
Re: ATO COde
Sorry, but you will need to give some more info.
Why do you say it is not working??
What is it doing right now?
