no internal memory haunting me
JDP1130
Post by JDP1130 »
so i have a pre loaded program on my RA. i plugged in and installed and info on new computer and tried to change to access RA. screen went black then came back on with "no internal memory found" on screen. i attempted to load intmem form sketchbook and to restore pre loaded coded and nothing works. screen stays with "no internal memory found" on screen and red led "status bulb lit. Am i doomed?
Please advise
Re: no internal memory haunting me
Try adding this right above ReefAngel.Init() in your code or even the preloaded code:
InternalMemory.IMCheck_write(0xCF06A31E);
JDP1130
Post by JDP1130 »
ive tried the pre loaded code with no luck
Did you add the code I posted to the preloded code exactly where mentioned?
JDP1130
Post by JDP1130 »
I JUST DID AFTER FEEDING THESE KIDS...LOL...I NOW HAVE A MENU SCREEN AND SEEMS TO BE DIFFERENT VISUALLY BUT IT IS NOW OPERATIONAL I BELIEVE. WILL ADDING CODE BE SAME AS BEFORE?
Yeap :)
cheezischrist
Post by cheezischrist »
rimai wrote:Try adding this right above ReefAngel.Init() in your code or even the preloaded code:
im having kind of the same nightmare, but is there a certain way i have to type this in the code? comes up saying missing destructor, or something similar....gonna try it again, it was really late last night.
You can simply copy and paste.
