Wifi IP on RA display
alexwbush
Is there any way to display whether the wifi is connected and what the IP is on the RA display? I'd rather see that than try to decipher the flashing lights.
- Contact:
Re: Wifi IP on RA display
There's really not an easy way to do this. The reason is the wifi module is independent of the controller. All the IP stuff is handled on the wifi module. So I don't think this can be done.alexwbush wrote:Is there any way to display whether the wifi is connected and what the IP is on the RA display? I'd rather see that than try to decipher the flashing lights.
alexwbush
Bummer. I thought this might be the case. Thanks Curt.
Poiromaniax
set a static IP, and then use a sharpie with a label
http://forum.reefangel.com/viewtopic.php?f=14&t=3427
