Hello,
Hoping someone can help. My Wifi worked for two month and now it stopped working. I worked through some of the fixes in the forum with little luck. I have the attachment blinking green, but I get the Port 2000 to only forwarded to 0.0.0.0
Here is the code from the WiFi Utility (miss my real SSID):
Opening Serial Port...
Verifying speed at 9600 baud
Connected to serial port COM12
> set u b 57600
> set s p 0
> save
> reboot
Verifying speed at 57600 baud
Removing connection to COM12
< CMD
> reboot
< reboot
Wifi Attachment Connected to COM12
< CMD
> ls
< ls
< FL#    SIZ   FLAGS
<   2  79680   3 WiFly_GSX-2.36
<  22   1052  10 config
<  23   1052  10 user
<  24  86328   3 wifly-GSX-400
<  25  88548   3 wifly-GSX-441-r1057
<  34  83648   3 WiFly_GSX-2.45
<  79  46632   3 wps_app-GSX-131
<  80  66240   3 eap_app-GSX-101
<  81  74920   3 web_app-GSX-106
<  82  37282   0 web_config.html
<  83    512   0 link.html
< 104 Free, Boot=25, Backup=24
< <4.41>
> load user
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> save
< save
< Storing in config
< <4.41>
> set o d ReefAngelWifi
< set o d ReefAngelWifi
< AOK
< <4.41>
> set w l 5
< set w l 5
< AOK
< <4.41>
> set w s xxxxx
< set w s xxxxx
< AOK
< <4.41>
> set w p xxxx
< set w p xxxx
< AOK
< <4.41>
< AOK
< <4.41>
< set ftp address 198.175.253.161
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> reboot
< reboot
< CMD
> show n
< show n
< SSid=xxxxx
< Chan=11
< Assoc=OK
< Rate=12, 24Mb
< Auth=OK
< Mode=MIXED
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=1
< <4.41>
> get i
< get i
< IF=UP
< DHCP=ON
< IP=0.0.0.0:2000
< NM=0.0.0.0
< GW=0.0.0.0
< HOST=198.171.134.6:80
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.41>
> reboot
< reboot
Found router SBG6580
Port 2000 is now being forwarded to 0.0.0.0
Troy
						WiFi is not working Port 2000 is now being forwarded to 0.0
				HodagReef
				howaboutme
Re: WiFi is not working Port 2000 is now being forwarded to
I had the same issues. Use WPA-2 and it should work.
							Jack
I'm assuming you used Tera Term already, so can you connect to connect to the module and post the results of the "get e" command?
What I'm trying to find out is if the setting for Wireless-->Join is set to 1.
				HodagReef
Rimai - back from holiday and had a chance to look at few more things. What I found was my setup of Dynamic DNS service was not working.. My password in the router was work. It's back working.
