You have to go into your Router setting and set your firewall to relay information that comes from the RA on port 2000 to and from the outside world/portal.lion-clown wrote:I don't know what you are talking about when you say:
"Did you setup port forwarding for port 2000 in your router and did you set up a DNS server so wen you IP address changes it will pick it up and continue working?
Also have to set your router to assign a static IP address to the RA?
You don't want that to change every time you reboot the RA or router."
But I hope to have some time tomorrow to play with it.
Once port 2000 is open to traffic you will need to set up a DNS service (like with no-ip.com).
This will see when your ISP assigned IP address changes and update their records to the new IP address and when you assign a DNS name (mine is sacohen.no-ip.biz) that name gets entered into your phone.
Once your DNS name is set up the Portal will see all your information. (Temps, PH, ATO, Relays On/Off) from the RA head unit and populate everything to the Portal and to your phone as well.
