Emergency shutoff when water rises
Decatur5717
I’m looking for a bit of code that will turn my return pump off (port1) if…… float switch (connected to ATO high) triggers. Then, if for whatever reason port1 shuts off also turn off port3
Earlier today I was working on the tank and turned off the return pump, without realizing it the water dropped enough to cause the circulation pumps (port3 and their sole purpose is to stir up the surface so I don’t get so much stagnant water) to spit water all inside the hood shorting out one of the lights. Needless to say I’ve adjusted it so it will not happen again but still, if my return pump cuts off I need to cut those ports as well. If the float switch activates then I’m about a half inch from disaster
Any ideas?
Any ideas?
Re: Emergency shutoff when water rises
if (ReefAngel.ATOHigh.IsActive()) ReefAngel.Relay.Override(Port1,0);
if (!ReefAngel.Relay.Status(Port1)) ReefAngel.Relay.Override(Port3,0);
Decatur5717
And that'd look like this correct?
ReefAngel.LightsOnPorts = Port2Bit | Port4Bit | Port6Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 815 );
ReefAngel.Relay.On( Port3 );
ReefAngel.StandardLights( Port2,8,0,20,30 );
ReefAngel.StandardLights( Port4,7,30,20,0 );
ReefAngel.StandardHeater( Port5,790,795 );
ReefAngel.StandardLights( Port6,7,0,2,0 );
ReefAngel.StandardLights( Port7,11,0,6,0 );
ReefAngel.StandardLights( Port8,2,0,21,0 );
Decatur5717
hmmm doesn't like that??
"Class reefangelclass" has no member named "atohigh"
Decatur5717
Do I need to remove this?
And changing it to highato got me passed the checks
Decatur5717
lol that worked in reverse
Decatur5717
second test and it's working as expected, Excellent! Thanks buddy
Not sure why it cut off the first time
