Prevent Dosing Pump "ON" Override
jolt
Not sure how it happened, but I found one of my dosing pumps to be overridden "ON".
Has anyone else already written a routine to prevent a dosing pump from remaining indefinitely overridden as "ON" (indefinite override of "OFF" should always be allowed though)
Re: Prevent Dosing Pump "ON" Override
Yes. I added into the library an option to define ports that are never allowed to be overridden. It works for both on and off though...however you can change the value on the fly using a few different methods...so for me i turn an unused port on and then i can override my dosing pumps. When i'm done i turn that port back off. Loon for the OverridePorts statement in my INO for an example
jolt
jolt
Hi Lee -
I tried grabbing your code for this but I am obviously missing something important in how the RA build process works.
I stuck this in my loop() function (dosers on ports 7 and 8)
I get compile errors:
jims_sketch_mar08:81: error: 'class ReefAngelClass' has no member named 'OverridePortsE'
I notice that the definition of OverridePortsE in ReefAngel.h is surrounded by #ifdef OVERRIDE_PORTS
What I can't figure out is where to define that. I don't see a corresponding #define in your code. Tried putting it in ReefAngel_Features.h but it just gets blown away, apparently by the IDE. Tried hacking it into Globals.h, and no luck
What's the magic?
Than ks,
Jim
// don't allow doser ports to be overridden
ReefAngel.OverridePortsE[6] = 0;
ReefAngel.OverridePortsE[7] = 0;
What's the magic?
Than ks,
Jim
Theres a function i call...think its in setup or maybe in that code block that "activated" that feature...
I think its ReefAngel.AllowOverride() ? I forget...but you can figure it out if you look in feature.txt
jolt
Hmmm, I think something is still missing in my understanding/execution of this simple task.
I added this to my sketch, as you suggested:
Still getting the same error message:
I see that this function is defined in ReefAngel.h as follows:
But even after adding this call to my code the definition of OverridePortsE is still not enabled, apparently due to this #define structure in ReefAngel.h:
So can someone explain to me the "magic" that leads from calling an inline function (ReefAngel.AddPortOverrides()) in my sketch and having OVERRIDE_PORTS auto-magically defined for the C preprocessor?? I'm sure there is something going on under the hood, but it is not obvious to me...
I am happy to read through an old thread if I knew what I was looking for, so if it exists please point me in the right direction ....
Jim
ReefAngel.AddPortOverrides();
void inline AddPortOverrides() {};
byte OverridePortsE[MAX_RELAY_EXPANSION_MODULES];
#endif // OVERRIDE_PORTS
Jim
Can you look at your feature.txt file and see if you have a line for OVERRIDE_PORTS in it?
jolt
It took me a while to find this file, I was not aware it existed. I found it in a folder called 'update', so I assume that is the one you are referring to.
No text 'OVERRIDE_PORTS' in that file.
Found your discussion of that here:
http://forum.reefangel.com/viewtopic.php?f=11&t=2328
Added the line to feature.txt:
Now this shows up in ReefAngel_features.txt:
Here is a simple sketch I am testing this with:
OVERRIDE_PORTS,ReefAngel.AddPortOverrides(),Override Port RelayMasks
- OVERRIDE_PORTS,ReefAngel.AddPortOverrides(),Override Port RelayMasks
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.Relay.DelayedOn( Port3 );
ReefAngel.DayLights( Port4 );
ReefAngel.Relay.DelayedOn( Port5 );
ReefAngel.StandardHeater( Port6 );
ReefAngel.DosingPumpRepeat1( Port7 );
ReefAngel.DosingPumpRepeat2( Port8 );
ReefAngel.Portal( "XXX" );
Yes, it's in the update folder. Sounds like you have the right file.
When you compile what features do you see being enabled?
You can try manually #define 'ing the OVERRIDE_PORTS in ReefAngel/ReefAngel.h and ReefAngel/ReefAngel.cpp for the worst case...
You might need that in some other files that reference #ifdef OVERRIDE_PORTS... maybe easier to just stick it in Globals\Globals.h
jolt
Assuming you are asking about ReefAngel_Features.h.
After I updated features.txt I get this:
But it still gives the compile error
jims_sketch_apr30:75: error: 'class ReefAngelClass' has no member named 'OverridePortsE'
#define SIMPLE_MENU
#define OVERRIDE_PORTS
#define SALINITYEXPANSION
#define FONT_8x8
#define MAIN_2014
#define wifi
#define DisplayLEDPWM
#define VersionMenu
#define WDT
#endif // __REEFANGEL_FEATURES_H__jims_sketch_apr30:75: error: 'class ReefAngelClass' has no member named 'OverridePortsE'
How many relay expansions you have? Take off the E[x] if you are trying to do this on the main relay bar. The 6 and 7 in your code refer to the 6th and 7th relay expansion not the port.
Assigning 0 to these variables will not override any ports.
If you want to override port 6 & 7 do this...
ReefAngel.OverridePorts = Port6Bit | Port7Bit;
jolt
