Buzzer not working.
Buzzer not working.
In the wizard when I get to the daylight dimming channel I select buzzer because that's what I have it plugged in.
Then at the end of the wizard where it says buzzer - please check when the buzzer will come on I check overheat and ATO timeout.
It has never worked when the ATO times out or it overheats.
The buzzer works because every time I unplug the unit the buzzer rings for a few seconds till the head unit boots up.
Re: Buzzer not working.
byte buzzer=0;
byte overheatflag=0;
byte atoflag=0;
ReefAngel.FeedingModePorts = Port4Bit;
ReefAngel.WaterChangePorts = Port4Bit | Port5Bit;
ReefAngel.LightsOnPorts = Port7Bit | Port8Bit;
ReefAngel.SingleATOLow( Port1 );
ReefAngel.StandardFan( Port3 );
ReefAngel.DosingPumpRepeat1( Port4 );
ReefAngel.DosingPumpRepeat2( Port5 );
ReefAngel.DosingPumpRepeat3( Port6 );
ReefAngel.DayLights( Port7 );
ReefAngel.ActinicLights( Port8 );
ReefAngel.DCPump.ExpansionChannel[0] = Sync;
ReefAngel.DCPump.ExpansionChannel[1] = AntiSync;
buzzer = overheatflag + atoflag;
if ( buzzer >= 1 ) buzzer = 100;
ReefAngel.PWM.SetDaylight( buzzer );
ReefAngel.Portal( "Trevenator" );
byte buzzer=0;
byte atoflag=0;
Code looks good.
When you have ATO timeout or overheat, does the red status led turn on and what do you see on the screen for the daylight channel value?
Yes red light turns on and ATO pump stops and then you have to go into the menu and reset the ATO timeout.
And in the portal the ATO high turns red.
But you use ATO Low...
What's ATO High?
What's ATO High?
No sorry I got that wrong they are both red and the ATO low turns green when the pump is on.rimai wrote:But you use ATO Low...
What's ATO High?
There is something wrong.
ATO High should not change state if you are not using. Do you also have a float switch on ATO high port?
Are you sure you have the float switch in the correct ATO port?
Your code is using ATO Low. You should connect the float on ATO Low port.
Yes I looked at the portal wrong. Its only the ato low that changes green when the pump is on.
The ato high never changes.
Its plugged in to the ato low.
It works fine as far as shutting off the pump etc when it times out.
It just will not sound the buzzer.
Ok, when it is supposed to sound the buzzer, what do you see in the screen on the daylight channel?
On the portal it shows buzzer 0%rimai wrote:Ok, when it is supposed to sound the buzzer, what do you see in the screen on the daylight channel?
On my reef angel screen there is nothing to show the daylight or antic
I just have at the top of the screen its shows channel 0-5
channel 0 is my jebo wp40 so it shows like 780
channel 1 is my jebo wp40 so it shows like 810
channel 2 is unused so 0
channel 3 is unused so 0
channel 4 is unused so 0
channel 5 is unused so 0
then temp 1-3 on the left below that
then ph and dp and ap to the right of the 3 temps
below that I have the water level and salinity
on the bottom is the 8 blocks for what plug has power.
dp is the daylight channel. What does it show for dp when ATO is timed out?
it shows 0rimai wrote:dp is the daylight channel. What does it show for dp when ATO is timed out?
and I just reloaded the code after I downloaded the new library.
so now it shows dimming on the led screen
So after I let the ato timeout and the red light comes on the controller and it shuts the ato pump off
its shows
dimming
daylight 0
actinic 46
the actinic 46 is my moonlight hub
if I plug the buzzer in to the actinic it rings so I know its not a hardware problem
Here is the code again
Its just from the wizard. No changes from me
byte buzzer=0;
byte atoflag=0;
byte buzzer=0;
byte atoflag=0;
Not sure what is going on...
Let's change your code...
Replace this:
With this:
Replace this:
buzzer=ReefAngel.AlerFlags;
when I do that it says
sketch_may06a:96: error: 'class ReefAngelClass' has no member named 'AlerFlags'
when I try to upload
Ahh never mind I see we are missing a t in
buzzer=ReefAngel.AlertFlags;
Great that works.
Buzzer sounds when ato times out.
That also fixed it not sending a email when It times out like a had posted over at
http://forum.reefangel.com/viewtopic.php?f=20&t=4572
So it killed 2 birds with one stone.
