This is a new reef angel. It operates properly without the expansion plugged in. However, when I plug the expansion in the status light continuously blinks and none of the ports work. I also get no readings when I try and calibrate the water level module. The water level expansion worked on the reef angel on my other tank and it is not a bad USB cable because I tried one that does work. I am also using the 1.1.0 libraries. Any help would be appreciated.
Status light blinks with water level expansion plugged in
Re: Status light blinks with water level expansion plugged i
The only way we will find out is by trying out each piece at a time with your other system unless you want to send it all back for me to take a look at it.
The first thing you should try is swapping the svga cable. If that doesn't work, try swapping the relay box.
I suspect it is one of the two.
I will try swapping things out first. I am headed out of town for a few days right now so I will try that when I get back.
Alright it is working now with the single channel water level expansion module so all is well currently.
