I have just compiled this using the Wizard. I am getting a "too big" error. I need the features to be configured as Ive set them, but if it helps, I need next to nothing on the controller screen - PH and temp only (would be nice if the text was large but if it keeps the sketch small then i dont mind regular size text)
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port7Bit;
ReefAngel.OverheatShutoffPorts = Port4Bit;
ReefAngel.Relay.On( Port7 );
ReefAngel.DayLights( Port1 );
ReefAngel.DayLights( Port2 );
ReefAngel.DayLights( Port3 );
ReefAngel.StandardHeater( Port4 );
ReefAngel.Wavemaker1( Port5 );
ReefAngel.RF.UseMemory = true;
ReefAngel.Portal( "poiromaniax" );
int x,y;
// Parameters
// pH Expansion
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,66, "PHE:" );
ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.PHExp,COLOR_MEDIUMSEAGREEN,39,66, 100 );
// Main Relay Box
// Date and Time
