Wanting to do a code overhall
Dctrojan
Post by Dctrojan »
Ok im wanting to update my current code with a improved code which accomplishes the following things:
-Turn wavemaker on nutrient transport mode after feeding is over for 4 hours.
-Turn DC pump off for 2 hours after entering feeding mode.
-I also want my protein skimmer to remain off for 4 hours after pressing the feeding button.
could anyone point me in the right direction with a example of that?
Im mostly confused on where do i place the custom code in my current code. Also could someone explain to me how do i get my code to show up in a scroll box in a post? I cant seem to figure it out. I press the CODE button and insert my code.
Thanks for all the help.
Summer_high_lights_slope.ino
    ReefAngel.AddPHExpansion();  // pH Expansion Module
    ReefAngel.FeedingModePortsE[0] = Port1Bit | Port2Bit | Port4Bit;
    ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit | Port4Bit;
    ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port8Bit;
    ReefAngel.OverheatShutoffPortsE[0] = Port3Bit | Port4Bit | Port5Bit;
    InternalMemory.OverheatTemp_write( 829 );
    ReefAngel.DCPump.WaterChangeSpeed=100;
    ReefAngel.StandardLights( Port1,14,30,20,00 ); ////// White t5
    ReefAngel.StandardLights( Port2,13,00,22,00 ); ////// blue t5
    ReefAngel.StandardLights( Port3,12,00,23,00 ); ////// reefblok blue
    ReefAngel.StandardLights( Port4,14,00,21,00 ); ////// reefblok white
    ReefAngel.StandardLights( Port5,14,30,21,00 ); ////// custom led
    ReefAngel.StandardLights( Port6,14,0,23,0 ); ////// uv
    ReefAngel.StandardLights( Port7,22,0,13,0 ); ////// night light
    ReefAngel.StandardHeater( Port8,800,820 );
    ReefAngel.StandardLights ( Box1_Port4, 12,0,22,00 ); ////// protein skimmer
    ReefAngel.SingleATO( true,Box1_Port6,66,0 );
    ReefAngel.PWM.SetChannel( 0, PWMSlope(13,30,22,0,5,40,60,5) ); ////// whites
    ReefAngel.PWM.SetChannel( 1, PWMSlope(12,0,23,0,5,100,60,20) ); ////// blue reefblok
    ReefAngel.PWM.SetChannel( 2, PWMSlope(14,0,22,0,5,100,60,5) ); ////// blue
    ReefAngel.PWM.SetChannel( 3, MoonPhase() );
    ReefAngel.PWM.SetDaylight (62); ////// Dc pump
    ReefAngel.DCPump.SetMode( NutrientTransport,90,100 ); ////// wavemaker
    ReefAngel.DCPump.ExpansionChannel[0] = None;
    ReefAngel.Portal( "Dctrojan" );
Re: Wanting to do a code overhall
I think it is time for us to have a variable to hold the time of the last feeding. More and more people are trying to do that and it would make things easier to code.
I'll add to the github issues
Sent from my SM-G900P using Tapatalk
Try this:
time_t StartFeeding=0;
time_t StopFeeding=0;
boolean Feeding=false;
    if (!Feeding && ReefAngel.DisplayedMenu==FEEDING_MODE)
      Feeding=true;
      StartFeeding=now();
    if (Feeding && ReefAngel.DisplayedMenu!=FEEDING_MODE)
      Feeding=false;
      StopFeeding=now();
    if (now()-StopFeeding < 4*SECS_PER_HOUR)
      // NTM for 4 hours after feeding
    if (now()-StartFeeding < 2*SECS_PER_HOUR)
      // Turn DC Pump off
      ReefAngel.PWM.SetDaylight (0); ////// Dc pump
    if (now()-StartFeeding < 4*SECS_PER_HOUR)
      // Turn Skimmer off
      ReefAngel.Relay.Off(Box1_Port4);
Dctrojan
Post by Dctrojan »
Thanks so much for taking a look at my code. I'll try it out later on today.
Dctrojan
Post by Dctrojan »
okay after trying the code it works great. i plan on tweaking it slightly . but now for some reason my reefblok blue leds aren't working. i've narrowed it down to either a bad connection on a driver wire or the programming to the driver. i know the power to the led isn't the problem. is there anywhere in the code that the pwm set channel 1 is canceled?
No. Nothing has been changed on that.
