Hi, Brand new to Reef Angel, just got my RA Plus Unit and Wifi attachment yesterday. All hardware is working correctly and I'm able to load code. I ran wifi setup successfully, uploaded wifi test code, but not able to connect with browser. The setup gave me 1.2.3.4:2000 which doesn't look right. When I connect the wifi to the head unit I see green blinking light, but when I type that address in firefox it just says connecting... then times out. I reran the wifi setup several times, each time I get the same results: 1.2.3.4:2000. When I bring up DHCP Client Table in the router settings, I don't see any reef angel connection. I do notice, however, that when I connect the wifi to the head unit, I can no longer connect to the internet with my macbook pro. I also can't login with ps3 which normally uses wifi as well. Looks like some kind of conflict. After I unplug reef angel wifi and restart the router I'm back up on the internet with Macbook pro and ps3. When I check DHCP client in the router settings, I see macbook pro on 192.168.1.121, but no reef angel, though I also don't see ps3 connection even though I'm logged in--which leads me to believe that reef angel could be up and running but how would I know what internal ip to check? But either way, it's still bringing down my wifi.
I'm using Cisco E3200 router with Windows 7 Desktop and Macbook Pro laptop connected through wifi (when Reef Angel's wifi is not plugged in).
Here's the code I saw when setting up the wifi:
Opening Serial Port...
Verifying speed at 9600 baud
Connected to serial port COM3
> set u b 57600
> set s p 0
> save
> reboot
Verifying speed at 57600 baud
Removing connection to COM3
< CMD
> reboot
< reboot
Wifi Attachment Connected to COM3
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 2 86328 3 wifly-GSX-400
< 4 74920 3 web_app-GSX-106
< 7 46632 3 wps_app-GSX-131
< 9 66240 3 eap_app-GSX-101
< 11 37282 0 web_config.html
< 21 512 0 link.html
< 24 -1 10 config
< 169 Free, Boot=2, Backup=2
< <4.00>
> set c c 0
< set c c 0
< AOK
< <4.00>
> set c r 0
< set c r 0
< AOK
< <4.00>
> set c o 0
< set c o 0
< AOK
< <4.00>
> set c i 3
< set c i 3
< AOK
< <4.00>
> set c s 1420
< set c s 1420
< AOK
< <4.00>
> set d n ww.reefangel
< set d n ww.reefangel
< AOK
< <4.00>
> set i h 198.171.134.6
< set i h 198.171.134.6
< AOK
< <4.00>
> set i r 80
< set i r 80
< AOK
< <4.00>
> set i f 0x6
< set i f 0x6
< AOK
< <4.00>
> set w j 1
< set w j 1
< AOK
< <4.00>
> set u m 2
< set u m 2
< AOK
< <4.00>
> set i p 2
< set i p 2
< AOK
< <4.00>
> set o d ReefAngelWifi
< set o d ReefAngelWifi
< AOK
< <4.00>
> set w l 5
< set w l 5
< AOK
< <4.00>
> set w s Todd
< set w s Todd
< AOK
< <4.00>
> set w p b******1
< set w p b******1
< AOK
< <4.00>
< AOK
< <4.00>
< set ftp address 198.175.253.161
< AOK
< <4.00>
> save
< save
< Storing in config
< <4.00>
> reboot
< reboot
< CMD
> show n
< show n
< SSid=Todd
< Chan=11
< Assoc=OK
< Rate=12, 24Mb
< Auth=OK
< Mode=MIXED
< DHCP=OK,renew=-6
< Boot=204
< Time=FAIL
< Links=1
< <4.00>
> get i
< get i
< IF=UP
< DHCP=SERVER
< IP=1.2.3.4:2000
< NM=255.255.255.0
< GW=1.2.3.4
< HOST=198.171.134.6:80
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.00>
> reboot
< reboot
Found router Linksys Series Router E3200
Unable to setup port forwarding. This step will have to be done manually. For more information for your specific type of router, please visit ww.portforward
wifi issues
wifi issues
Re: wifi issues
Just in case, can you try doing this:
Re: wifi issues
Thanks Roberto, I'll give this a try later on
Re: wifi issues
Here's what tera term put out to the screen, though I don't see any new IP address to try. What next?
CMD
save
Storing in config
<4.00> set wlan ssid Todd
AOK
<4.00> set wlan pass b******1
AOK
<4.00> set option deviceid ReefAngelWifi
AOK
<4.00> set w j 1
AOK
<4.00> set c c 0
AOK
<4.00> set c r 0
AOK
<4.00> set c o 0
AOK
<4.00> set i d 1
AOK
<4.00> set c i 3
AOK
<4.00> set dns name http://reefangel
AOK
<4.00> set i h 198.171.134.6
AOK
<4.00> set i r 80
AOK
<4.00> set i f 0x06
AOK
<4.00> set s t 0x10
AOK
<4.00> set u m 2
AOK
<4.00> set i p 2
AOK
<4.00> set u b 57600
AOK
<4.00> set s p 0
AOK
<4.00> set c s 1420
AOK
<4.00> save
Storing in config
<4.00> save user
Storing in user
<4.00> reboot
*Reboot*CMD
factory RESET
Set Factory Defaults
<4.00> reboot
*Reboot*CMD
AOK
<4.00> save
Storing in config
AOK
AOK
<4.00> set option deviceid ReefAngset w j 1
AOK
<4.00> set c c 0
AOK
<4.00> set c r 0
AOK
<4.00> set c o 0
AOK
<4.00> set i d 1
AOK
<4.00> set c i 3
AOK
AOK
AOK
<4.00> set i r 80
AOK
<4.00> set i f 0x06
AOK
<4.00> set s t 0x10
AOK
<4.00> set u m 2
AOK
<4.00> set i p 2
AOK
AOK
<4.00> set s p 0
AOK
<4.00> set c s 1420
AOK
<4.00> save
Storing in config
<4.00> save user
Storing in user
<4.00> reboot
*Reboot*HTTP/1.1 400 Bad Request
Content-Type: text/html
Date: Fri, 30 May 2014 10:08:59 GMT
Connection: close
Content-Length: 35
CMD
save
Storing in config
AOK
AOK
AOK
<4.00> set w j 1
AOK
<4.00> set c c 0
AOK
<4.00> set c r 0
AOK
<4.00> set c o 0
AOK
<4.00> set i d 1
AOK
<4.00> set c i 3
AOK
AOK
AOK
<4.00> set i r 80
AOK
<4.00> set i f 0x06
AOK
<4.00> set s t 0x10
AOK
<4.00> set u m 2
AOK
<4.00> set i p 2
AOK
AOK
<4.00> set s p 0
AOK
<4.00> set c s 1420
AOK
<4.00> save
Storing in config
<4.00> save user
Storing in user
<4.00> reboot
*Reboot*CMD
factory RESET
<4.00> reboot
*Reboot*CMD
AOK
<4.00> save
Storing in config
AOK
AOK
AOK
<4.00> set c c 0
AOK
<4.00> set c r 0
AOK
<4.00> set c o 0
AOK
<4.00> set i d 1
AOK
<4.00> set c i 3
AOK
AOK
AOK
<4.00> set i r 80
AOK
<4.00> set i f 0x06
AOK
<4.00> set s t 0x10
AOK
<4.00> set u m 2
AOK
<4.00> set i p 2
AOK
AOK
<4.00> set s p 0
AOK
<4.00> set c s 1420
AOK
<4.00> save
Storing in config
<4.00> save user
Storing in user
<4.00> reboot
Connection: close
Content-Length: 35
Re: wifi issues
I don't think it worked either.
It seems the router doesn't want to give an address or vice-versa.
Using tera term, if you type $$$ you will go into command mode.
The module will respond with CMD
Then, use this command:
get e
Post the response.
Was this module purchase new?
get e
Post the response.
Re: wifi issues
Ok thanks. will try that tonight. Also, I'm not sure if I did the above steps correctly toward the end. Wasn't sure whether to have the wifi utility running also? I'm not that great with networking.
Re: wifi issues
It worked! I'm not sure exactly what I did, but I ran the tera term, then configuration again but this time it assigned an internal IP (Security is set back to WPA2/WPA Mixed mode)
Now I'm getting problems accessing from outside the network. Here's what I've done:
1. turn off Windows Firewall
2. setup port forwarding
app: reef angel
Ext port: 2000
Int port: 2000
Protocol: both (TCP UDP)
IP address: 192.168.1.100 (the ip that works internally)
Enabled: yes
This url brings up the interface: http://192.168.1.100:2000/wifi
When I put http://x.x.x.x:2000/wifi connection times out
where x.x.x.x is the ip my provider assigns to my computer (in router status)
Thanks for all your help!
Todd
app: reef angel
Ext port: 2000
Int port: 2000
Enabled: yes
Todd
Re: wifi issues
Restarted router and now port forwarding is working (I can see if from outside the network), though there's a new problem. It assigned a different local IP address, and I couldn't see it in the router settings until I unplugged and replugged in the wifi attachment. Is there a way to force it to a specific internal ip? e.g. 192.168.1.121?
Re: wifi issues
Your router should have something for that.
It's called ip reservation. It's based on MAC address.
