I'm a bit confused as to where to put the code or if it replaces anything. I used the portal to create the initial code. It is below and I put the code you suggested in where I think you said it goes. But I get the feeling that I am suppose to replace the DCPump lines. With this code below, it also gave me an error " 'else mode' not declared in this scope." Does this go back to question #1, do I call this mode? If so, where?
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port5 );
ReefAngel.DayLights( Port3 );
ReefAngel.ActinicLights( Port4 );
ReefAngel.PWM.SetActinic( ElseMode(37,7,true)); // ElseMode on sync mode, 37 +/- 7%
ReefAngel.Portal( "howaboutme" );
