IOS App Help
NTeal
IOS App Help
Post by NTeal »
So I've got my controller working along with the wifi attachment. My port forwarding and everything has been set up. On my wifi I can get readings sent to the app however when using cellular data it says connection failed The request timed out. Ive tried different settings and looked through the forums and can't find a solution. Can anyone help?
Re: IOS App Help
I think port forwarding is not setup correctly or you are using the wrong ip address.
When on cellular data, you must use the external ip address of your wifi network.
You can find out what that ip address is by visiting http://www.yougetsignal.com/tools/open-ports/
You can also test the port in that website to ensure your port forwarding is correctly setup.
NTeal
Re: IOS App Help
Post by NTeal »
rimai wrote:I think port forwarding is not setup correctly or you are using the wrong ip address.
Thanks! I got it figured out and it was an error on my part. Thanks again!
Christo
Re: IOS App Help
Post by Christo »
[THUMBS UP SIGN]
