jaebo return pump?
jaebo return pump?
So if i order a DC 1200l Jaebo return pump and 3 wp 40s ill be able to run them all on my dimming add on? anyone run a DC return pump on the RA?
Re: jaebo return pump?
Yes and you'll still have 2 ports free, plus the ones on your mail relay box. Roberto is running a dc pump i believe.
I do. My original Speedwave crapped out as well as my original power supply. Ever since I changed to Jebao, it is been running smoothly until today the same way
Check my post here:
http://forum.reefangel.com/viewtopic.php?p=28750#p28750
Check my post here:
So i still have the old regular reef angel with opti boot..... am i in need of upgrade to do everything i want here? Ill have my main tank and a 29g bio cube. I have a dimming add on (to control 3 jaebo powerheads and a dc return pump and possibly diy led in the bio cube at some point), ato for both tanks (probably lift pump on bicube and RA ato pump on main tank, plan on having 2 RA power supplies one for each tank to control my ac stuff heaters standard pumps ect. idk how capable this old ra unit is of managing all this code. What yah think?
