![Image](http://farm4.static.flickr.com/3393/5743104503_53bc5d6304_z.jpg)
As you can see, I have 2 power blocks, WiFi adapter (which I got working/connected to my network), and a PWM add-on. I have tried the Dev libraries, can update the controller all day long with the software, but I can't configure any of the power ports nor can I do anything with my PWM controller. When I use the Dev libraries it makes the LCD screen on the controller worthless (meaning you can't use it, it just displays info). Setting it up with the software that is available is easy to understand, but won't work for my setup, and I am a little lost about what files to manually edit to be able to configure my power ports and PWM signals. Do I add the info in the .pde file I got with the PWM add-on with another file or do I make a call from one file to the pwm.pde file?
Thanks for steering me in the right direction.
![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
