I had an ATO already when I bought the reefangel, so I was wondering if I could program a port to only come on for say 20 minutes every hour, or every couple of hours?
This way, if my current ATO gets stuck on, it won't flood my house!
Port only on for X minutes every hour?
Re: Port only on for X minutes every hour?
Many different ways of doing, but I'd just use this:
if (minute()<=20) ReefAngel.Relay.On(Port1); else ReefAngel.Relay.Off(Port1);
agentgreen
Clever.
dpitalo
Let's say you're using the same type of idea for a dosing pump, but you only want each pump run for 20 seconds 5 minutes apart once per day, would the code look like this??
if (hour()==8 && minute()==0 && second()<=20) ReefAngel.Relay.On(Dosing1); else ReefAngel.Relay.Off(Dosing1);
if (hour()==8 && minute()==5 && second()<=20) ReefAngel.Relay.On(Dosing2); else ReefAngel.Relay.Off(Dosing2);
