ANDROID RA STATIC APP ISSUE HELP ?
Hi guys got the RA Status app VRS. 0.9.5 installed on a Note 3 Samsung for about a year now, everything works fine except the commands section, in particular I'm trying to use the "Feeding Mode" when selected it has no effect but if i check the the main relay page on the app, it actually shows the channels that are allocated to "Feed Mode" are turned off eg. pumps wave maker etc. but it is actually not turning them off. it also show on the flags page that feed mode is active.
any help would be great as I'm sick of turning everything on and off manually.
thanx !
thanx !
Re: ANDROID RA STATIC APP ISSUE HELP ?
just to be clear, when you press feeding mode, the app connects to your controller. the app shows the ports off but the ports do not actually get turned off. is that correct?
do you hear the ports toggle off and then back on?
you can manually turn them on/off though, right?
that seems odd. can you enter feeding mode from the controller itself? I'm thinking maybe you have an issue with your feeding mode timer being set to 1 second or something very short. can you check that value?
Sent from my Moto X
Sent from my Moto X
Yes that is correct, I can enter feed mode from the unit directly with no issues at all. I can manually turn the ports on and off, cannot here relays toggle on and off ???
how long is the feeding mode timer set for?
i have not heard of this happening. try to toggle the feeding mode the same way the app does which is via the web command.
try issuing this command:
where YOURIP is your controller's ip address and PORT is the port (typically 2000).
http://YOURIP:PORT/mf
HI thanx for that when i runt the command over http it returns this below
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<MODE>ERR</MODE>
any idea ???
<MODE>ERR</MODE>
any idea ???
feeding mode time is set correctly and it works fine manually from the controller.
that means that there was an error when the controller was trying to enter feeding mode from the wifi interface. I'm not positive as why this is happening, maybe roberto has an idea.jcondello wrote:HI thanx for that when i runt the command over http it returns this below
<MODE>ERR</MODE>
any idea ???
Sent from my Nexus 7
Very weird.
Are you using the latest libs?
ERR would occur if you try to enter feeding mode but you are already in feeding or water change mode.
Please explain libs ?? I have just used the wizard to set all my gear up ??
I find somtimes it does go into feed mode but will turn off all the gear allocated to feed mode, but it works fine I enter feed mode directly from the unit ???
Sorry will not turn off.
Sorry, I just re-read the OP.
If it has been a year, it could be very well the libs version.
I think there was a patch at some point in time within this year timeframe.
Did you try reloading the same code?
You can see what version your libraries are running in the head unit if you press the joystick and go to menu version.
You can also see what version of libraries you have installed in your computer by going to menu Tools->Reef Angel Libraries Version.
Make sure they are both 1.1.0, which is the latest version.
