Error uploading. (please help)
alexwbush
Post by alexwbush »
I am trying to get an older basic RA up and running on a quarantine tank.
I am getting "Error uploading." with the following details:
Watchdog Timer
Version Menu
Relay Expansion Module
Number of Relay Expansion Modules: 1
Standard Menu
Binary sketch size: 27,752 bytes (of a 30,720 byte maximum)
E:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CE:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P\\.\COM1 -b57600 -D -V -Uflash:w:C:\Users\ORBITO~1\AppData\Local\Temp\build8438675645450573292.tmp\sketch_aug04b.cpp.hex:i
avrdude: Version 6.0, compiled on Apr  6 2012 at 19:29:19
         System wide configuration file is "E:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : \\.\COM1
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 57600
avrdude: Send: 0 [30]   [20]
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x0c
avrdude done.  Thank you.
89delta
Re: Error uploading. (please help)
Post by 89delta »
Do you have Reef Angel Controller w/ optiboot selected and are on the correct port
alexwbush
Post by alexwbush »
I'm not sure if it's optiboot or not. I've selected w/ and w/o optiboot. I've also tried the two ports that were options.
No dice. I'll try again when I get home.
alexwbush
Post by alexwbush »
Still having problems... I can upload to my RA+ just fine, but my original RA does not upload w/ and w/o optiboot on the correct serial port.
Is there a way to reset the board to factory with the new UI? Or is it too big of a file?
Watchdog Timer
Version Menu
Wifi Attachment
Simple Menu
Binary sketch size: 31,200 bytes (of a 32,256 byte maximum)
E:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CE:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -carduino -P\\.\COM3 -b115200 -D -V -Uflash:w:C:\Users\ORBITO~1\AppData\Local\Temp\build8680866803544489014.tmp\sketch_aug10f.cpp.hex:i
         Using Port                    : \\.\COM3
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x64
It would be too big.
Does the controller reboot a few seconds after you hit upload?
alexwbush
Post by alexwbush »
it might be restarting. It flashed like it's uploading and then goes black and back to the previous program. Should I avoid programming with the wizard all together with the basic RA?
I thought it was okay since it said the sketch size is 31,200 bytes and the max is 32,256
Should be the same. It might be the head unit itself.
