Reading Energy Use
Rodasphoto
Reading Energy Use
Post by Rodasphoto »
Is there anyway to view how much energy is being consumed by equipment plugged into relays?
Re: Reading Energy Use
Not directly with the RA.
You can use a device call a Kill-A-Watt .
http://www.homedepot.com/p/Unbranded-Ki ... /202196386
We could probably do something where we log the amount of time a port is on and track it based on a set wattage or something :) It wouldn't be actual usage, but it could be good if we wanted to get some idea the amount of power being used...
Rodasphoto
Its a feature I saw on an Apex that I saw when I was picking up some coral from a fellow reefer and since we own the BEST controller on the market I thought I would ask if there was a way to do it built in. Thanks for the recommendation on the kill-a-watt.
johniii
Post by johniii »
lnevo wrote:We could probably do something where we log the amount of time a port is on and track it based on a set wattage or something :) It wouldn't be actual usage, but it could be good if we wanted to get some idea the amount of power being used...
Could we not use a CT on the power wire with the proper code?
Sent from my SCH-I510 using Tapatalk 2
Whats a CT?
johniii
Post by johniii »
lnevo wrote:Whats a CT?
A CT is a coil of wire around an iron bar that detects magnetic flux and converts to amps. Let me see if I can find an example.
Lol I found a whole article on how to use one on an arduino
http://openenergymonitor.org/emon/build ... -interface
So it sounds like this is something we can hook to the IO board and then clamp around the incoming power to the relay box and measure overall power? Or to individual outlets..?
johniii
Post by johniii »
lnevo wrote:So it sounds like this is something we can hook to the IO board and then clamp around the incoming power to the relay box and measure overall power? Or to individual outlets..?
Either or both. But remember it can only go around 1 wire, the hot. If you run a hot and neutral through it the flux will cancel each other out. Causing a 0 reading.
Ahh so it needs to be integrated then inside the relay box or stripping your power plug (no thanks) :)
Roberto what do you say? Next gen relay box?
johniii
Post by johniii »
lnevo wrote:Ahh so it needs to be integrated then inside the relay box or stripping your power plug (no thanks) :)
Yes. But you could get a weather proof box and cover. And make your taps in there with the proper wire connectors. Would be no worse than the taps behind your electrical outlet.
Piper
Post by Piper »
+1 That's exactly what I was thinking. Just make an inline box that plugs into the wall that has an outlet for the relay box. Very interesting add-on idea here though. I might have to check into this when I have a bit more time.
Definitely a good upgrade for next gen relays too!
~Charlie
Rodasphoto
Apex has it on each outlet of the relay. It would be nice to incorporate that same feature. For the rest of us total amps would be easier.
johniii
Post by johniii »
Rodasphoto wrote:Apex has it on each outlet of the relay. It would be nice to incorporate that same feature. For the rest of us total amps would be easier.
Even with total amps our loads are pretty constant. You would be able to tell when a heater comes on or if something is amiss by a simple trend graph like web chart. What is the benefit of having it on each individual outlet
Rodasphoto
See what piece of equipment is being an energy hog to plan for future upgrades. To see if an individual piece of equipment is working.
My old Reef Keeper Lite had this feature, IIRC. It seemed horribly inaccurate.
