Kessil A360 Color Spectrum Question
Well my Kessil A360WE will be here Friday and I want to be able to come up with a code that allows me to adjust the color spectrum from the controller so I can visually see the color and corresponding dimmer % so I can chose the proper value for my ramp times. Any help would be greatly appreciated!!
Re: Kessil A360 Color Spectrum Question
No, it's on my list but probably still a month away from purchasing
It's much easier with the WiFi... I think the best route is for you to use the preloaded code.
Sent from my SM-G900P using Tapatalk
By that do you mean using the wizard to randomly pick values until I find one I like?
No, restore to the preloaded code.
It will let you change the max % with your joystick.
Problem I have is that I can't go below 11% in spectrum without the light turning off. if I unplug my cord I can get much more blue that running though the controller
Once you know the % you want you can go back to your other code and use the new % to update that code.
That isn't the problem, the problem is that any time the color intensity is set below 11% the light just turns off. I knew that was an issue with intensity but haven't heard of problems dropping color all the way down to 1%
How do you do this with the wifi attachment?rimai wrote:It's much easier with the WiFi... I think the best route is for you to use the preloaded code.
Use the smartphone app to override the dimming channels
