#include <Wire.h>fF
#include <RA_NokiaLCD.h>f
// Define Relay Ports by Name
#define Actinic_Lights 1
#define Day_Lights 2
#define Kalkwasser 3
#define Pumps 4
#define Sump_Fan 5
#define DeNit_Doser 6
#define DeNit_Pump 7
#define ATO_Pump 8
#define Unused Box1_Port1
#define Feeder Box1_Port2
#define Unused Box1_Port3
#define Unused Box1_Port4
#define Unused Box1_Port5
#define Unused Box1_Port6
#define Unused Box1_Port7
#define Dummy Box1_Port8
// Does not need to be global.
// unsigned long ATOUpdate=0;
ReefAngel.WaterChangePorts = Port4Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit;
//Set Standard Menu
ReefAngel.AddStandardMenu();
//Webserver Authentication
ReefAngel.Network.WifiAuthentication("Sacohen:xxxxxxxx");
//DDNS Server
ReefAngel.DDNS("xxxxxxxx");
ReefAngel.DCPump.DaylightChannel=AntiSync; // Now you're pump will be affected by the portal settings.
ReefAngel.DCPump.AntiSyncOffset=0;
ReefAngel.Relay.On( Pumps );
ReefAngel.Relay.On( Dummy );
ReefAngel.StandardLights( Actinic_Lights,12,0,22,0 );
ReefAngel.StandardLights( Day_Lights,13,0,21,0 );
ReefAngel.StandardLights( Sump_Fan,13,0,21,0 );
ReefAngel.WaterLevelATO(ATO_Pump,720,28,31);
if ( hour()>=13 && hour()<21 )
ReefAngel.PWM.SetChannel( 5, 0 );
ReefAngel.PWM.SetChannel( 5, PWMSlope(21,0,13,0,0,MoonPhase() ,60,0) );
//Mix Kalkwasser
static unsigned long Kalk_Mixing = 0;
static unsigned long stopTime = 0;
static byte prevWL=0;
if (ReefAngel.WaterLevel.GetLevel(1)>=100 && prevWL<100) {
stopTime=now()+3600; // Get time one hour from now.
prevWL = ReefAngel.WaterLevel.GetLevel(1); // Store the water level
if (now() < stopTime) { ReefAngel.Relay.On(Kalkwasser); } else { ReefAngel.Relay.Off(Kalkwasser); }
//AutoFeeder
static unsigned long autofeeding = 0;
if ((now()%SECS_PER_DAY==64800)) //if it is 6 pm
ReefAngel.FeedingModeStart(); //START FEEDING MODE
if ( autofeeding == 0 ) {
autofeeding = now(); //set the time of the start of feeding to variable feeding
if ((now()-autofeeding>=60) && (now()-autofeeding<=61)) //if between 60 and 61 seconds has past
ReefAngel.Relay.On(Feeder); //TURN FEEDER RELAY ON
ReefAngel.Relay.Off(Feeder); //TURN FEEDER RELAY OFF
} else {
if ( autofeeding > 0 ) {
autofeeding = 0;
// DeNitrate Routine
int DeNit_Offset=3600;
int DeNit_Repeat=21600;
int DeNit_Doser_Offset=1200;
int DeNit_Doser_Runtime=600;
int DeNit_Pump_Runtime=1200;
int DeNit_ATO_Offtime=1500;
// Pump comes on first
ReefAngel.Relay.Set(DeNit_Pump,(now()-DeNit_Offset)%DeNit_Repeat<DeNit_Pump_Runtime); // Runs denitrator pump
// Doser comes on second
ReefAngel.Relay.Set(DeNit_Doser,((now()-DeNit_Offset)-DeNit_Doser_Offset)%DeNit_Repeat<DeNit_Doser_Runtime); // Runs denitrator doser
// Disable ATO
if ( (now()-3600)%21600<DeNit_ATO_Offtime) ReefAngel.WaterLevelATO(ATO_Pump,720,0,1);
// Delay WL ATO after water change and DeNit_Dosing
static time_t wcTimer=0;
if (ReefAngel.DisplayedMenu == WATERCHANGE_MODE) wcTimer=now();
// First 10 minutes after WC disable ATO
if (now()-wcTimer >= 0 && now()-wcTimer < 600)
// Track Salinity low duration
static unsigned long lastGoodSal;
static boolean lowSalFlag;
// Salinity is good, update counter
if (ReefAngel.Params.Salinity>=335) lastGoodSal=now();
// Counter hasn't been updating in 300 seconds..
if (now()-lastGoodSal>300) {
lowSalFlag=true; // Salinity is definitely below 33.5
} else {
lowSalFlag=false; // Salinity back to normal
// Disable ATO if lowSalFlag is true
if (lowSalFlag) ReefAngel.WaterLevelATO(ATO_Pump,720,0,1);
// Disable ATO if ATO High IsActive()
static int rmode;
byte modes[] = { ReefCrest, Lagoon, Constant, TidalSwell, ShortPulse, LongPulse, Else };
changeMode=false;
static unsigned long feeding;
if (now()-feeding<3600) {
} else if (now()%SECS_PER_DAY<43200 || now()%SECS_PER_DAY>=79200) { // 12pm / 10pm
// Night mode (go to 30%)
ReefAngel.DCPump.Speed=30;
ReefAngel.Portal( "Sacohen","xxxxxxxx" );
int x,y;
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,57, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,57, ReefAngel.WaterLevel.GetLevel() );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,66,66, "WL 1:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,66, ReefAngel.WaterLevel.GetLevel(1) );
//Salinity
strcat(text," ");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,39,75,"Salinity:");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,99,75,text);
ReefAngel.LCD.DrawOutletBox(12, 104, TempRelay);
I also re uploaded it to my controller so you can see if it shows up in the server again.
