Different settings for 2 different DC Pumps.
Re: Different settings for 2 different DC Pumps.
As far as I know you just have to reset the device.
- Sacohen
No. The pump will just stop and you will need to pull the power from it to get it started again.
AlanM
The default threshold if you've never run the dev code before should be 30 percent. Did that not happen? I tried to detect if that memory location had anything in it and if it didn't it would do 30% and write that there until you change it to something else.
The new RW series Jebao pumps can supposedly be run down to 10%, but that's with the Jebao controllers, so it's possible that it's not really 10% of 0-5V, just that the controller has 10 speed settings to choose from which the retailers market as "can be dimmed down to 10%." I'm getting some in the next few days, so I'll let folks know at what voltage they cut off.
ReEfnWrX
It's not. My WP-40 turns off at 19% and my WP-25 turns off at 24% Connected to Daylight/Actinic channelsSacohen wrote:I have a WP-25 and a WP-40.
The cut off on my WP-40 is 25% and my WP-25 is 30%.
I can't say that is the limit for all of them thought.
Out of curiosity, which ports are you using? I wonder if they cut off at different %'s based on whether they are connected via Analog dimming/PWM Dimming / Actinic-Daylight channels.
- Sacohen
My 40 is on the actinic and my 25 is on the daylight. PWM.
