Lighting code
mask0017
Lighting code
Hi i was wondering if anyone could tell me how to turn on port 5 of the relay box at 06:00 and off at 08:05 then on at 18:00 and off at 20:05
know nuthing about coding
Mask0017
Mask0017
- Contact:
Re: Lighting code
This could work for you.mask0017 wrote:Hi i was wondering if anyone could tell me how to turn on port 5 of the relay box at 06:00 and off at 08:05 then on at 18:00 and off at 20:05
Mask0017
ReefAngel.StandardLights(Port5, 6, 0, 8, 5);
ReefAngel.StandardLights(Port5, 18, 0, 20, 5);
mask0017
Re: Lighting code
this is my code now does that look okay?
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 285 );
ReefAngel.StandardATO( Port1,120 );
ReefAngel.Relay.DelayedOn( Port2,5 );
ReefAngel.StandardHeater( Port3,252,255 );
ReefAngel.StandardLights( Port4,20,0,8,0 );
ReefAngel.StandardLights( Port6,8,10,19,50 );
ReefAngel.StandardLights( Port7,8,5,19,55 );
ReefAngel.DCPump.SetMode( TidalSwell,70,10 );
ReefAngel.Portal( "mask0017" );
Re: Lighting code
Actually, there is a need of a check or the 2nd function will always override the first.
This should work:
This should work:
if (hour()<12)
Re: Lighting code
I don't think that would work Curt. The second iteration would shut off the port from 6:00 - 8:05. It's not like the dimming code where you can nest it.
I would do this:
I'm using 12 as an arbitrary time to do one versus the other, so that can easily be changed to whatever you like.
LOL - Roberto came up with the same solution
I would do this:
if ( hour() < 12 ) {
ReefAngel.StandardLights(Port5,6,0,8,5);
} else {
ReefAngel.StandardLights(Port5,18,0,20,5);
mask0017
Re: Lighting code
heres my code now would that work?
if (hour()<12)
Thanks for the help totally lost with coding
if (hour()<12)
Re: Lighting code
Yes, but I would take out the extra Port5 calls earlier in the file just to avoid confusion
mask0017
Re: Lighting code
Thanks got that done will see how it goes.
Big thanks to everyone for the help
- Contact:
Re: Lighting code
Yeah, I was wondering about that. I couldn't remember off hand about the multiple statements in a row.
Guess I'm slipping and "losing my touch". haha
