Fan to kick on at set temperature?
DavidinGA
Post by DavidinGA »
I want to be able to turn a fan on in my canopy at a set temperature and then have it turn off either when the water temp drops or at a set time; how do I do that?
Say I want the fan to kick on when the water hits 82F and then kick off if it hits 81F or at a set time (the end of the mh light cycle).
    InternalMemory.OverheatTemp_write( 845 );
    ReefAngel.StandardHeater( Port1,795,800 );
    ReefAngel.StandardHeater( Port2,794,800 );
    ReefAngel.StandardLights( Port3,24,0,15,0 );   ////scrubber lights 12am-3pm  15hrs on 9off
    ReefAngel.StandardLights( Port4,16,0,24,0 );  ////Canopy Fan 4pm to 12am
    ReefAngel.StandardLights( Port5,16,0,23,0 ); ////Metal Halide 4pm to 11pm
    ReefAngel.DosingPumpRepeat( Port6,0,660,10 ); /////mag 720min = 11hrs  15ml day
    ReefAngel.DosingPumpRepeat( Port7,0,360,26 );  /////alk 360min = 6hrs  78ml day
    ReefAngel.DosingPumpRepeat( Port8,0,300,21 );  ////cal 300min = 5hrs   78.75ml day 3cups per gal
    ReefAngel.DCPump.SetMode( LongPulse,60,10 );
    if (hour()<8)
ReefAngel.PWM.SetActinic(0);
ReefAngel.PWM.SetDaylight(0);
else if (hour()==8 && minute()<4)
ReefAngel.DCPump.SetMode( LongPulse,85,20);
else if (hour()>=8 && hour()<10)
ReefAngel.DCPump.SetMode( ShortPulse,75,40 );
else if (hour()>=10 && hour()<12)
ReefAngel.DCPump.SetMode( LongPulse,85,4 );
else if (hour()>=12 && hour()<14)
ReefAngel.DCPump.SetMode( ReefCrest,56,20 );
else if (hour()>=14 && hour()<16)
ReefAngel.DCPump.SetMode( LongPulse,80,5 );
else if (hour()>=16 && hour()<22)
ReefAngel.DCPump.SetMode( LongPulse,75,14 );
else if (hour()==23 && minute()<4)
ReefAngel.DCPump.SetMode( LongPulse,90,5);
   ReefAngel.AddWifi();
    ReefAngel.Portal( "davidinga" );
    int x,y;
    // Parameters
    // pH Expansion
    ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,66, "PHE:" );
    ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.PHExp,COLOR_MEDIUMSEAGREEN,39,66, 100 );
    // Main Relay Box
    // Date and Time
Re: Fan to kick on at set temperature?
ReefAngel.StandardFan(PortX,81,82);
DavidinGA
Post by DavidinGA »
Didn't know their was a fan code. Lol
So...
ReefAngel.StandardFan(Port4,81,82);
Kicks the fans on at 82f and off at 81f?
Am I able to code in a window of time where that applies too?
Yeah we just need to wrap it in an if statement with the times you want. Are you using internal memory for your MH?
How about this instead of a time window? (this is easier to code/read)
if (ReefAngel.Relay.Status(Port5))
  ReefAngel.StandardFan(Port4,81,82))
  ReefAngel.Relay.Off(Port4);
This nice thing about that is that if you change your MH schedule or change it to use memory, it won't matter here.
If your halides are on then it will look to use the fan if necessary. Otherwise fan is off.
DavidinGA
Post by DavidinGA »
lnevo wrote:How about this instead of a time window? (this is easier to code/read)
Sweet.
So where would I put that code and what do I do with the existing code I have for the fan?
Comment it out. Put this in the custom section inside loop
DavidinGA
Post by DavidinGA »
Does my code look correct?
    if (hour()<8)
    int x,y;
    // Parameters
    // pH Expansion
    // Main Relay Box
    // Date and Time
What about the line:
Do I leave that in there like it is or what???
You can leave it, but I would comment it out or remove it to avoid confusion.
DavidinGA
Post by DavidinGA »
The code is not working.
    if (hour()<8)
    int x,y;
    // Parameters
    // pH Expansion
    // Main Relay Box
    // Date and Time
I click "Verify" and it says:
sketch_Oct_18_2014_Metal_Halides.cpp: In function 'void loop()':
sketch_Oct_18_2014_Metal_Halides:114: error: expected `;' before ')' token
So...I changed the error to this:
Which passed Verify. So I uploaded that to the RA+ and my fan port continues to run like before (my water temp on the probe is 80.6F btw).
What am I doing wrong here?
Ahh... Parameters are wrong. Replace this line:
With this:
ReefAngel.StandardFan(Port4,810,820);
DavidinGA
Post by DavidinGA »
K. I was wondering why I had 3 temperature digits on my heater lines and only 2 down here...
Sorry forgot about that
DavidinGA
Post by DavidinGA »
Thanks I got it working.
:D
