Hello,
I am new to this and need some help. I have my RA up and running. I ran the wizard and have everything setup the way I want, but there are a couple of things that are not addressed in the wizard. I have been reading up on the forums, and found some code, but I am in a little over my head. I don't know where to put the code or even if it's what I really need so... some help would be appreciated!
1) I have two PH probes. One in my reactor, and one in display. I need to define which relay will be controlled by each probe.
2) I have two Temp probes. One in DT, one in Sump. I need to define which relay will be controlled by each probe.
3) I have two float switches. One in sump, one in overflow. I need to define which relays will be controlled by each switch.
I imagine that the solution to each of these will look pretty similar, and I think I stumbled onto something of value in the ReefAngel library, but I don't understand this well enough yet. If offering help, please understand that simply posting code isn't going to get me there. I need some direction on how/what to do with the code.
I would like to start experimenting but I am not clear on the best way to save backups that I can revert back to.
Thanks in advance for your help!
Setup PH controls for CaRx, Temp, and ATO
Re: Setup PH controls for CaRx, Temp, and ATO
I think I have the PH, and Temps figured out. Will someone please review my work so far and tell me if it looks correct?
(Any Concerns/Improvements?)
Assuming all is good there, I am still trying to figure out how to ID and use two floats. One is for ATO function and the other is for emergency (in case of overflow shut off return)
ReefAngel.AddPHExpansion(); // pH Expansion Module
ReefAngel.FeedingModePorts = Port5Bit | Port7Bit;
ReefAngel.WaterChangePorts = Port2Bit | Port3Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port4Bit;
// Use T1 and T2 probe as temperature and T1 as overheat functions
ReefAngel.TempProbe = T1_PROBE | T2_PROBE;
ReefAngel.Relay.On( Port2 ); // Reactor Feed
ReefAngel.Relay.On( Port7 ); // Return Pump
ReefAngel.Relay.On( Port8 ); // Skimmer
ReefAngel.CO2Control( Port1 );
ReefAngel.SingleATOLow( Port3 );
ReefAngel.StandardHeater( Port4 );
ReefAngel.Relay.DelayedOn( Port5 );
ReefAngel.MoonLights( Port6 );
ReefAngel.CustomLabels[0]="CO2";
ReefAngel.CustomLabels[1]="Reactor";
ReefAngel.CustomLabels[2]="ATO";
ReefAngel.CustomLabels[3]="Heater";
ReefAngel.CustomLabels[4]="Power Heads";
ReefAngel.CustomLabels[5]="Fuge Light";
ReefAngel.CustomLabels[6]="Return";
ReefAngel.CustomLabels[7]="Skimmer";
if ( ReefAngel.Params.PHExp < 820 ) ReefAngel.Relay.Off( Port2 ); //Reactor Feed
if ( ReefAngel.Params.PHExp >= 840 ) ReefAngel.Relay.On( Port2 ); //Reactor Feed
ReefAngel.Portal( "mng777777" );
You need to add some custom code.
There is a section inside loop() like this:
That's where you place the code.
So, for #1:
You can use like this:
It will use your expansion module to turn on/off Port1.
Similar for #2:
It will use Temperature 2 to turn on/off Port2
For #3, it is the same concept with just different syntax:
And you can use LowATO or HighATO
So, for #1:
if (ReefAngel.Params.PHExp < 780) ReefAngel.Relay.Off(Port1);
if (ReefAngel.Params.PHExp > 790) ReefAngel.Relay.On(Port1);
Similar for #2:
if (ReefAngel.Params.Temp[T2_PROBE] < 780) ReefAngel.Relay.Off(Port2);
if (ReefAngel.Params.Temp[T2_PROBE]> 790) ReefAngel.Relay.On(Port2);
if (ReefAngel.LowATO.IsActive)
ReefAngel.Relay.Off(Port3);
ReefAngel.Relay.On(Port3);
I am getting this error:
sketch_oct26b:90: error: could not convert 'ReefAngel.ReefAngelClass::HighATO.RA_ATOHighClass::IsActive' to 'bool'
Use this:
The () after ReefAngel.HighATO.IsActive is missing.
