2nd relay box
2nd relay box
When I toggled my reef angel back on after a water change, my 2nd relay box did not turn back on. Any suggestions?
Re: 2nd relay box
The whole box, or just certain ports?
You can try unplugging the system to reset it, and check the cable and power to the expansion relay to make sure it's connected well.
If you have WiFi try toggling the ports via the portal or an app.
Re: 2nd relay box
Oh, and check the breaker on the expansion relay box.
