Power control expansion
pandimus
Post by pandimus »
Is there any Manu control of it via the apps etc? I didn't happen to see it in the wizard, nor the menus in apps for manual control. I'm looking to control several things like pumps and fans and some control manually would be nice
Re: Power control expansion
It acts just like an additional relay bar. Yes you can control it in all the apps/portal/etc.
pandimus
Post by pandimus »
So I just add it exactly like I has the expansion relay?
Yep you'll need to adjust the jumpers so it will have the right address if you already have an expansion.
pandimus
Post by pandimus »
lnevo wrote:Yep you'll need to adjust the jumpers so it will have the right address if you already have an expansion.
Thanks so much for your time
