Wizard woes
Lionfan
Wizard woes
Post by Lionfan »
So, trying to use the wizard to set up the RA. This is what I keep getting when trying to upload the code the wizard gives me.
Watchdog Timer
Version Menu
2014 Main Screen
Standard Menu
ReefAngel\ReefAngel.cpp.o: In function `__vector_9':
C:\Users\Matt Fish stuff\Documents\Arduino\libraries\ReefAngel/ReefAngel_1.5_LCD.h:4: multiple definition of `__vector_9'
SoftwareSerial\SoftwareSerial.cpp.o:C:\Program Files (x86)\Reef Angel Controller\libraries\SoftwareSerial/SoftwareSerial.cpp:305: first defined here
c:/program files (x86)/reef angel controller/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/bin/ld.exe: Disabling relaxation: it will not work with multiple definitions
This is the code I'm trying to upload.
Watchdog Timer
Version Menu
2014 Main Screen
Standard Menu
Please help. Im about to throw this controller against the wall..
Re: Wizard woes
That's a bug that should not have been there.
It's related to the new Arduino that was release a couple days ago.
Let me check it out.
Lionfan
Re: Wizard woes
Post by Lionfan »
Have you figured out the bug? And what should I do to get it back up and running?
Re: Wizard woes
Can I see the code you are trying to upload?
Lionfan
Re: Wizard woes
Post by Lionfan »
Here's the code from the wizard.
#include <SoftwareSerial.h>
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <Salinity.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <AI.h>
#include <PH.h>
#include <WaterLevel.h>
#include <Humidity.h>
#include <DCPump.h>
#include <PAR.h>
#include <ReefAngel.h>
    ReefAngel.FeedingModePorts = Port7Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port7Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port5Bit;
    ReefAngel.Relay.On( Port2 );
    ReefAngel.StandardATO( Port3 );
    ReefAngel.DosingPumpRepeat1( Port4 );
    ReefAngel.StandardHeater( Port5 );
    ReefAngel.DayLights( Port7 );
Lionfan
Re: Wizard woes
Post by Lionfan »
Also, as I'm sitting looking at the controller (i restored the factory code) the screen will cut off, and the red status led will blink, nd then it will flash back on. Idk if that's part of the problem?
Lionfan
Re: Wizard woes
Post by Lionfan »
Re: Wizard woes
Ok, I found the problem.
I need to update the wizard.
Please remove this line:
Your code should compile now.
Lionfan
Re: Wizard woes
Post by Lionfan »
Yelp, that's it works now. Thanks a bunch. How would I code a graph into the main screen?
Re: Wizard woes
You need to remove this:
You can also redesign and create your own screen:
http://forum.reefangel.com/viewtopic.php?f=14&t=109
Lionfan
Re: Wizard woes
Post by Lionfan »
Thanks. I think I'm getting the hang of this. Its starting to make sense.
