Main Menu features
Re: Main Menu features
That's pretty much it... just not sure why you should have full voltage on the dimming channels at midnight...
does the number of digits for zero's have anything to do with it?
{0 -or- 00 -or- 000}
right now is 3.40 pm in my PC and the RA+ is late 3 minutes (last time they were synced 3 days ago), today I am running the slope from the same program above
ch0 = 00
ch1 = 000
ch2 = 800
ch3 = 77
ch4 = 0
ch5 = 980
ch0 = 00
ch1 = 000
ch2 = 800
ch3 = 77
ch4 = 0
ch5 = 980
The 0s are the remaining of the 100 that was previously drawn in the screen.
Your custom screen is not clearing the zeros. If you click the joystick to enter menu and exit it out, it will force a full refresh in the screen, which clears the zeros.
any work around possible with 0 Volts to ram up to 10V and back to 0 Volts on the dimming module?
So I can assume the dimming expansion module is "as is" ?
There should be no issue going 0V-10V-0V. Try loading the controller test code.
"controller test code"
Where can I find it, what and how to do it to post back?
