Can someone please tell me what I need to do to enable this. I apologize if this is such a newbie question.
I have read on the forum as much as I could make out, but unable to determine exactly what I need to do. Good news is this is the only thing I have left to have the controller the way I want it.... for now at least.
Thanks for any help you guys can offer.
ReefAngel.FeedingModePorts = Port3Bit | Port4Bit | Port6Bit | Port7Bit;
ReefAngel.WaterChangePorts = Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
ReefAngel.Relay.On( Port7 );
// Define labels for 2014 LCD screen
ReefAngel.CustomLabels[0]="Metal Halide";
ReefAngel.CustomLabels[1]="Heater";
ReefAngel.CustomLabels[2]="Return";
ReefAngel.CustomLabels[3]="BP Reactor";
ReefAngel.CustomLabels[4]="Skimmer";
ReefAngel.CustomLabels[5]="JBJ ATO";
ReefAngel.CustomLabels[6]="Wavemaker";
ReefAngel.CustomLabels[7]="Moon Light";
ReefAngel.MHLights( Port1,15,0,0,0,10 );
ReefAngel.StandardHeater( Port2,780,785 );
ReefAngel.Relay.Set( Port8, !ReefAngel.Relay.Status( Port1 ) );
ReefAngel.PWM.SetDaylight( PWMSlope(8,0,1,0,15,100,120,15) );
ReefAngel.DCPump.SetMode( Else,50,10 );
ReefAngel.Portal( "SlimyEel" );
