Switching ATO port based on pH
KRavEN
Post by KRavEN »
About to start testing this method and wanted to get some feedback.
Here's the method and then I just call setATO(); in the loop.
uint8_t atopump = -1;
void setATO(){
  // If waterlevel is greater than 60
  if(ReefAngel.WaterLevel.GetLevel(1) > 60)
    // if the pH is greater than 8.2 then top with RO
    if(ReefAngel.Params.PH > 820)
      if(atopump != ROPump) {
        ReefAngel.WLATO.StopTopping();
        ReefAngel.Relay.Off(KalkPump);
        atopump = ROPump;
    // if pH less than 8.2 top with Kalk
      if(atopump != KalkPump) {
        ReefAngel.Relay.Off(ROPump);
        atopump = KalkPump;
    ReefAngel.WaterLevelATO(1, atopump);
  // if waterlevel is less than 60 then there is no level data
  // or something else is wrong so stop everything
Lionfan
Re: Switching ATO port based on pH
Post by Lionfan »
Genius.
