My code - now with RAnet
bencollinz
bencollinz
Re: My code
I would like my mp10s to go into feeding mode when I choose feeding mode from the menu...how would I go about doing that?
bencollinz
Re: My code
oh. cool. didn't know that. I'm on 1.03, haven't updated for awhile...it will still do that?rimai wrote:it does it automatically.
bencollinz
Re: My code
yes it does, just tried it out. very cool!bencollinz wrote:oh. cool. didn't know that. I'm on 1.03, haven't updated for awhile...it will still do that?rimai wrote:it does it automatically.
bencollinz
Re: My code
ok, so feeding mode isn't strong enough flow. How do I tell it to go to short pulse 53% @ 25 duration when I go into feeding mode?
Re: My code
You can change the feeding mode speed on the Ecotech driver without having to do any code change. I believe it keeps the mode that you are in.
You can adjust the speed and duration for this mode using the EcoSmart Configuration mode. See Section 4.5: Configuration Mode for instructions on how to do this. The default speed is set to 50% slower than the lowest speed of the pump for a duration of 10 minutes.
Re: My code
Setting 1: Barely Spinning
Setting 2: 50% lower than lowest speed of pump
Setting 3: lowest speed of pump
Setting 4: 25% speed of pump
Setting 5: 50% speed of pump
Re: My code
The only reason I suggest this route is that I like to see my drivers blinking in feeding mode
You could certainly set it in code, but then you lose the nice light show
bencollinz
bencollinz
Re: My code
wow, your code is insane! I tried to pick through it to figure out NTM mode after exiting feeding mode for a set amount of time and just got entirely lost. is there an easier way?lnevo wrote:The only reason I suggest this route is that I like to see my drivers blinking in feeding modeYou could certainly set it in code, but then you lose the nice light show
Re: My code
It's actually pretty straight forward, but my code does a lot...
So during feeding mode, I update a variable with the current time. When feeding mode stops that variable stops getting updated and I know when feeding mode ends.
Then during each pass of loop() you can check that varaible and run NTM for whatever amount of time you want:
I left the ... in place of whatever you want to do. Keep in mind if you have other scheduling overrides and modes happening, you'll need to make that if part of that loop or do it after... this is where my stuff gets more complex and will probably similar in your code.
static unsigned long feeding;
if (ReefAngel.DisplayedMenu==FEEDING_MODE) {
feeding=now();
if (now()-feeding > 1 && now()-feeding < 3600) { // 1 second after feeding mode until 60 minutes after feeding mode.
... // Run your smart_ntm here.
bencollinz
Re: My code
like this?
void_loop(){
if (hour() >=8 && hour() < 22)
if (ReefAngel.RF.Mode==Night) ReefAngel.RF.SetMode(Feeding_Stop,0,0);
ReefAngel.RF.UseMemory=true;
feeding=now();
ReefAngel.RF.SetMode(vtMode,vtSpeed,vtDuration);
ReefAngel.Relay.Off(Port8);
ReefAngel.RF.UseMemory=false;
ReefAngel.Relay.On(Port8);
ReefAngel.Portal( "bencollinz" );
bencollinz
Re: My code
I see that
No worries. I'll see what I can do on the trainride home for you.
Re: My code
Actually it looks like you got it. The only thing you need to add is to set UseMemory false if you are doing SetMode like that. Otherwise it looks good.
Don't forget to declare the feeding variable...the static unsigned long feeding; statement. It can be inside the loop function, as long as its before the test.
Good work!
Good work!
bencollinz
Re: My code
ok, but I want it to function as follows...lnevo wrote:Actually it looks like you got it. The only thing you need to add is to set UseMemory false if you are doing SetMode like that. Otherwise it looks good.
Good work!
between 8am and 10pm I want it to use whatever setting from memory (ie. portal)
if between 8am and 10pm I go into feeding mode then for 1 hour afterwards it does NTM mode
otherwise it's nite mode ie. ReefAngel.RF.UseMemory=false; ReefAngel.RF.SetMode(Night,15,0);
is that making sense? or am I misunderstanding how this works?
bencollinz
Re: My code
or like this?
void_loop(){
feeding=now();
}- lnevo
bencollinz
bencollinz
Re: My code
so after adding the RAnet into my code the "clear ATO" from the menu no longer functions and just stays stuck on the click to continue screen (after clicking clear ato)
any advice?
clear ato works fine from the android app though
#include <SoftwareSerial.h>
#define Heater 1
#define Return 2
#define HeaterTk2 3
#define Skimmer 4
#define Vortech1 5
#define Vortech2 6
#define ATO 7
#define Sump Light 8
byte vtechmode, vtSpeed, vtDuration;
ReefAngel.FeedingModePorts = Port2Bit;
// ReefAngel.FeedingModePortsE[0] = 0;
// ReefAngel.WaterChangePorts = Port7Bit | Port4Bit | Port5Bit | Port6Bit;
// ReefAngel.WaterChangePortsE[0] = 0;
// ReefAngel.LightsOnPorts = 0;
// ReefAngel.LightsOnPortsE[0] = 0;
// ReefAngel.OverheatShutoffPortsE[0] = 0;
ReefAngel.AddRANet();
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
// Hardcode calibrations
ReefAngel.PHMin=576; // PH7.0
ReefAngel.PHMax=842; // PH10.0
ReefAngel.SalMax=3300; // 35ppt
vtechmode=InternalMemory.RFMode_read();
vtSpeed=InternalMemory.RFSpeed_read();
vtDuration=InternalMemory.RFDuration_read();
ReefAngel.StandardHeater( Port1,778,782 );
ReefAngel.WaterLevelATO( Port7,180,71,74 );
ReefAngel.StandardLights( Port8,15,0,2,0 );
ReefAngel.PWM.SetChannel( 0,PWMSlope(19,00,21,00,15,51,20,0) ); //MOON
ReefAngel.PWM.SetChannel( 1,PWMSlope(12,30,20,00,15,50,30,0) ); //RB
ReefAngel.PWM.SetChannel( 2,PWMSlope(12,20,20,00,15,95,30,0) ); //WHITE
ReefAngel.PWM.SetChannel( 3,PWMSlope(12,15,20,00,15,70,30,0) ); //BLUE&CYAN
ReefAngel.PWM.SetChannel( 4,PWMSlope(12,00,20,30,15,70,30,0) ); //UV
if ( ReefAngel.HighATO.IsActive())
ReefAngel.Relay.On(Port2);
ReefAngel.Relay.Off(Port2);
if (hour() >=13 && hour() < 20)
// if (ReefAngel.RF.Mode==Night) ReefAngel.RF.SetMode(Feeding_Stop,0,0);
// ReefAngel.RF.SetMode(ReefCrest,60,20);
feeding=now();
if (now()-feeding<5400) {
// if (now()-feeding > 1 && now()-feeding < 5400) { // 1 second after feeding mode until 60 minutes after feeding mode.
ReefAngel.RF.SetMode(Smart_NTM,75,10);
ReefAngel.RF.SetMode(Constant,10,0);
if (vtechmode!=InternalMemory.RFMode_read())
InternalMemory.RFMode_write(vtechmode);
if (vtSpeed!=InternalMemory.RFSpeed_read())
InternalMemory.RFSpeed_write(vtSpeed);
if (vtDuration!=InternalMemory.RFDuration_read())
InternalMemory.RFDuration_write(vtDuration);
char text[7];
// Date and Time
ReefAngel.LCD.DrawDate( 6, 2 );
ReefAngel.LCD.DrawText(0,255,18,12,"EcoSmart Vortech");
ReefAngel.LCD.Clear(255, 1, 19, 128, 29);
if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,21,"Constant");
else if (vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,21,"Lagoon");
else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,21,"Reef Crest");
else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,21,"Short Pulse");
else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,21,"Long Pulse");
else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,21,"Nutrient Trnsp.");
else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,21,"Tidal Swell");
else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,21,"Night");
ReefAngel.LCD.DrawText(0,255,4,30,"RF Speed:");
ReefAngel.LCD.Clear(255,59,29,128,39);
ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,71,31,vtSpeed);
ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,90,31,"/");
ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,100,31,vtDuration);
ReefAngel.LCD.DrawText(0,255,10,40,"Salt");
ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 50, text, Num8x8);
/* ReefAngel.LCD.DrawText(0,255,50,40,"Fresh");
ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 50, 50, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,100,40,"pH");
ReefAngel.LCD.DrawLargeText(COLOR_PLUM, 255, 85, 50, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,13,58,"Salinity");
ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 13, 68, text, Num8x8);
// water level
ReefAngel.LCD.DrawText(0,255,68,58,"WL");
ReefAngel.LCD.DrawText( COLOR_CORNFLOWERBLUE,255, 68, 68, ReefAngel.WaterLevel.GetLevel() );
// Main Relay Box
ReefAngel.LCD.DrawOutletBox( 12, 108, TempRelay );
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 120, TempRelay );
/* void Heater2(byte HeaterRelay, int LowTemp, int HighTemp)
if (ReefAngel.Params.Temp[T2_PROBE] == 0) return; // Don't turn the heater on if the temp is reading 0
if (ReefAngel.Params.Temp[T2_PROBE] <= LowTemp && ReefAngel.Params.Temp[T2_PROBE] > 0) ReefAngel.Relay.On(HeaterRelay); // If sensor 2 temperature <= LowTemp - turn on heater
if (ReefAngel.Params.Temp[T2_PROBE] >= HighTemp) ReefAngel.Relay.Off(HeaterRelay); // If sensor 2 temperature >= HighTemp - turn off heater
void Heater1(byte HeaterRelay, int LowTemp, int HighTemp)
if (ReefAngel.Params.Temp[T1_PROBE] == 0) return; // Don't turn the heater on if the temp is reading 0
if (ReefAngel.Params.Temp[T1_PROBE] <= LowTemp && ReefAngel.Params.Temp[T1_PROBE] > 0) ReefAngel.Relay.On(HeaterRelay); // If sensor 2 temperature <= LowTemp - turn on heater
if (ReefAngel.Params.Temp[T1_PROBE] >= HighTemp) ReefAngel.Relay.Off(HeaterRelay); // If sensor 2 temperature >= HighTemp - turn off heater
*/clear ato works fine from the android app though
Re: My code - now with RAnet
I was able to replicate the issue.
It's related to the RANet code indeed.
This will be fixed in the next update.
https://github.com/reefangel/Libraries/issues/202
bencollinz
there's also a bug when it exits feeding mode it changes the vortechs to 100% constant.rimai wrote:I was able to replicate the issue.
well, in my code after it exists the smart_ntm part of it after 5400 seconds it then changes the vortechs to 100% constant. and again, i need to reboot to fix it.
bencollinz
I confirmed this again after tonight's feeding.bencollinz wrote:there's also a bug when it exits feeding mode it changes the vortechs to 100% constant.rimai wrote:I was able to replicate the issue.
I think that's your code doing that. Can you comment out your feeding routine section in full and verify that it exists as a bug.
bencollinz
I commented this outlnevo wrote:I think that's your code doing that. Can you comment out your feeding routine section in full and verify that it exists as a bug.
feeding=now();
{- lnevo
There was more that needed commenting. It would make no sense for your ra to put it into any particular mode after the 5400 seconds. Can you post the full code and I'll revert with the correct change.
bencollinz
lnevo wrote:There was more that needed commenting. It would make no sense for your ra to put it into any particular mode after the 5400 seconds. Can you post the full code and I'll revert with the correct change.
#define Heater 1
#define Return 2
#define 3
#define Skimmer 4
#define Vortech1 5
#define Vortech2 6
#define ATO 7
// ReefAngel.PHMin=576; // PH7.0
// ReefAngel.PHMax=842; // PH10.0
// ReefAngel.SalMax=3300; // 35ppt
/* if (ReefAngel.DisplayedMenu==FEEDING_MODE)
feeding=now();
// if (now()-feeding > 1 && now()-feeding < 5400) { // 1 second after feeding mode until 90 minutes after feeding mode.
char text[7];
// Date and Time
// water level
// Main Relay Box
// Relay Expansion
The calibration is related to the same issue.
The joystick button was not being debounced and was capturing two presses instead of one.
With the addition of the RANet, I had to disable the joystick button interrupt and make it software capture.
The new dev branch has this issue of the joystick button fixed.
If you download the latest dev branch, the joystick should work as intended.
Sorry for the late reply. Please try this code.
#define Heater 1
#define Return 2
#define 3
#define Skimmer 4
#define Vortech1 5
#define Vortech2 6
#define ATO 7
feeding=now();
char text[7];
// Date and Time
// water level
// Main Relay Box
// Relay Expansion
