Moonlights don't SEEM to be dimming.
I just replaced my Lunar hub because I thought it had water damage, but the problem still seems to exist.
My Moonlights don't seem to be dimming.
As I said I replaced the Lunar hub.
The code I'm using is...
if ( hour()>=13 && hour()<21 )
  ReefAngel.PWM.SetChannel( 5, 0 );
  ReefAngel.PWM.SetChannel( 5, PWMSlope(21,0,13,0,0,MoonPhase() ,60,0) );
I change the <21 to <13 and set the dimming channel to 20% thru the Andriod app.
It looked like it was full brightness.
The dimming channel was putting out about a little less than 2v so it is doing it's job, but the lights didn't look like 20% dimming
Re: Moonlights don't SEEM to be dimming.
If you connect just one moolight module directly to the dimming port, does it dim?
I'll try it.
It is dimming on both the lunar hub and dimming module.
I guess the difference was so minute that I didn't notice it unless I changed it and watched the lights the whole time.
Thanks anyway.
