HUUGE Favor
HUUGE Favor
I need a huge favor. I'm trying to change my reef angel's lcd screens and have no idea where to start. i used the wizard to upload my basic code and everything's working as i want, but i hate the screens on it. i would like my home screen to show temp, ph, and the relay box w/ whats on and off, also time and date. can someone help me with this. I'm not the techy type so i dont know where to start on this or where to even add it in.
Re: HUUGE Favor
Try removing the Use2014Screen command, you might like the older view
Re: HUUGE Favor
Ok if I used the wizard to program it where do I pull the code on the RA from?
Re: HUUGE Favor
You use the wizard and choose generate only.
Then you are going to see the code.
Remove the mentioned line and upload the code by clicking the icon on the top menu bar.
Re: HUUGE Favor
Ok also why can't I access my RA using my phones 4g?
Re: HUUGE Favor
I set up port forwarding. I can see it when I'm on wifi but not Verizon 4g
Re: HUUGE Favor
Re: HUUGE Favor
It says port is closed on my cell phone 4g. Also doesn't work when I connect to a nearby wifi at work.
Re: HUUGE Favor
You'll need to log in to your router and verify the forwarding. If you give us your model we can help find the directions etc
Re: HUUGE Favor
How do I make the changes to the screens like those instructions say to? I went to the port forwarding menu and put the RA wifi ip address and port number and saved it. Also gave it a static ip address.
Re: HUUGE Favor
Also for the actual forwarded port ip address should it start with 198? Mine starts with 198 right now.
Re: HUUGE Favor
So it should be 192 on the router?
Re: HUUGE Favor
Ok it's 192.168 on the router and the app. But still can't access from cell network or any other wifi
Re: HUUGE Favor
And the port forwarding site says it's closed. How do I open?
Re: HUUGE Favor
You need to setup port forwarding correctly or it will be closed.
Make sure you are forwarding port 2000 to the ip address that your router assigned to the wifi attachment.
It may not be the same you have already entered in the app.
Check in the list of connected devices in your router.
Until you get this figured out, the remote access won't work.
Re: HUUGE Favor
ok so ive tried deleting and re adding the ip/port to the port forwarding also followed the isntructions on the website posted earlier and i even got port forwarding software to do it for me and still no joy. what should i do? roberto could you do this for me?
Re: HUUGE Favor
rimai wrote:You need to setup port forwarding correctly or it will be closed.
im off work whenever you want to get started on the remote help just let me know. thanks in advance i greatly appreciate it
