RANet Cloud and Lightning
Re: RANet Cloud and Lightning
No, the lightning can happen whenever you want. The minute we send the trigger, the receiver will create the lightning effect for 5 to 10s.
This will happen even if the lights are full brightness, because the lightning will be trigger based now. But you can control when you want to send the trigger. so you can set it to trigger only when there is a cloud and only in certain clouds and not all of them.
jegillis
- cosmith71
It's already trigger based. The new version changes the mechanism of the trigger, but not the general principle of operation. The new version has a dedicated byte for the trigger, whereas the older one had the trigger hidden in one of the dimming channels.
The trigger is sent by the checkcloud function in the RA code. The receiver then generates a set of 1 to 4 flashes. The frequency of the trigger depends on the mode chosen.
There are variables in the checkcloud function that can be changed to adjust frequency of lightning, chance of lightning per cloud, etc.
Roberto's code is pretty much identical in the way the lightning is generated and the timing, which is what confuses me.
jegillis
Well I tried out my new bluetooth attachment and reloaded the controller code with the dev library and now instead channel 2 is flashing but not channel 1 video attached for the "flash".
response was still very slow but also stepped up and down instead of flashing
https://www.youtube.com/watch?v=eYNWTjKiiYs
jegillis
the new library had another effect, after the storm was over channel 0 and channel 2 shut off completely.
- cosmith71
The old RANet receiver code is incompatible with the new library.
jegillis
Ok, went back to the other library for now. Just noticed something that may be of help.
Where you would expect the lighting to ramp up the whites it is actually flashing off then back on to the level called for in the cloud. At no point during any flash does the light ramp up, like it is working in reverse.
- cosmith71
I'll be off work in a few hours. I'll take a look at it. That does help.
jegillis
In the latest receiver code posted you used a variable for the channels here
In the test code the channels are listed individually
Looking through attempting to understand why one would work but not the other. As you can see I am doing everything in my power to avoid studying for the bar exam I have to take in two weeks
for (int n=1; n<3; n++)
int newdata=4095;
Wire.beginTransmission(0x40); // Address of the dimming expansion module
Wire.write(0x8+(4*n)); // 0x8 is channel 0, 0x12 is channel 1, etc. I'm using channel 1.
Wire.write(newdata&0xff); // Send the data 8 bits at a time. This sends the LSB
Wire.write(newdata>>8); // This sends the MSB
Wire.endTransmission();
}Code: Select all
int a=random(5);
for (int i=0;i<a;i++)
newdata=4095;
Wire.write(0x8+(4*0));
Wire.write(0x8+(4*1));
Wire.write(0x8+(4*2));
delay(20+random(50));
newdata=0;
delay(30+random(20));
delay(random(1000));
- cosmith71
Yeah, I thought about that. Try this.
#include <avr/eeprom.h>
#define BLUE_LED 9
#define WHITE_LED 10
#define BLUE_INTENSITY 255
#define WHITE_INTENSITY 255
#define RANET_MAX_SIZE 64
#define DISCONNECT_TIMEOUT 2000
#define LastFallback0 100 // Memory location for fallback storage
#define RANet_Down 0
#define RANet_OK 1
byte Trigger=150; // Trigger value for lightning effect
byte TriggerChannel=1; // Channel to look for the trigger on
byte buffer_index;
byte buffer[128];
char buf[3];
byte bufint, bufsize;
byte RANetData[RANET_MAX_SIZE];
byte RANetCRC;
byte BlueChannel=0;
byte WhiteChannel=0;
byte RANet_Status=RANet_Down;
boolean cable_present=false;
unsigned long lastmillis=millis();
unsigned long lastcablecheck=millis();
pinMode(BLUE_LED,OUTPUT);
pinMode(WHITE_LED,OUTPUT);
Serial.begin(57600);
Wire.onReceive(NULL);
Wire.onRequest(NULL);
Wire.begin();
for (int a=0;a<RANET_MAX_SIZE; a++) // Clear array
RANetData[a]=0;
Wire.beginTransmission(0x68);
Wire.write(0);
int a=Wire.endTransmission();
cable_present=(a==0);
// setup PCA9685 for data receive
// we need this to make sure it will work if connected ofter controller is booted, so we need to send it all the time.
Wire.write(0);
Wire.write(0xa1);
if (cable_present)
BlueChannel=100;
WhiteChannel=0;
analogWrite(WHITE_LED,WHITE_INTENSITY*WhiteChannel/100);
analogWrite(BLUE_LED,BLUE_INTENSITY*BlueChannel/100);
BlueChannel=0;
WhiteChannel=0;
while(Serial.available())
UpdateWhiteChannel();
char c = Serial.read(); // Read each incoming byte
buffer[buffer_index]=c; // store in the buffer array
if (c==10) // if line feed we analyze the payload
if (buffer_index>25) // only need to analyse if buffer_index is greater than 25, otherwise the payload is broken or corrupt
if (buffer_index==buffer[1]) // check if payload matches the length the controller sent
RANetCRC=0;
for (int a=0; a<(buffer_index-2); a++) // calculate CRC
RANetCRC+=buffer[a];
if (RANetCRC==buffer[buffer_index-2]) // if CRC matches
for (int a=0; a<(buffer_index-2); a++) // Copy buffer to RANetData
RANetData[a]=buffer[a];
// Serial.print(millis());
// Serial.print("\t");
// Serial.println(RANetData[2]);
for (int a=0;a<8;a++)
if (eeprom_read_byte((unsigned char *) LastFallback0+a)!=RANetData[10+a])
eeprom_write_byte((unsigned char *) LastFallback0+a, RANetData[10+a]);
Wire.beginTransmission(0x38+a);
Wire.write(~RANetData[2+a]);
// Check for lightning trigger
if (RANetData[18+TriggerChannel] == Trigger) Lightning();
else // If the trigger has not been sent
for (int a=0;a<6;a++) // send along the data
int newdata=(int)(RANetData[18+a]*40.95);
Wire.write(0x8+(4*a));
RANet_Status=RANet_OK;
buffer_index=255; // reset buffer index
if (buffer_index++>=128) buffer_index=0; // increment index of buffer array. reset index if >=128
if (millis()-lastmillis>DISCONNECT_TIMEOUT)
// Serial.println("Disconnected");
// Serial.println(RANetData[10]);
Wire.write(~eeprom_read_byte((unsigned char *) LastFallback0+a));
if (RANet_Status==RANet_Down)
BlueChannel=0;
WhiteChannel=millis()%2000<1000?0:100;
void UpdateWhiteChannel()
WhiteChannel=sin(radians((millis()%7200)/40))*255;
BlueChannel=255-(sin(radians((millis()%7200)/40))*255);
analogWrite(WHITE_LED,WhiteChannel);
analogWrite(BLUE_LED,BlueChannel);
void Lightning()
int a=random(1,5); // Pick a number of consecutive flashes from 1 to 4.
for (int i=0; i<a; i++)
// Flash on
int newdata=4095;
Wire.write(0x8+(4*1)); // 0x8 is channel 0, 0x12 is channel 1, etc. I'm using channel 1.
Wire.write(0x8+(4*2)); // 0x8 is channel 0, 0x12 is channel 1, etc. I'm using channel 1.
int randy=random(20,80); // Random number for a delay
if (randy>71) randy=((randy-70)/2)*100; // Small chance of a longer delay
delay(randy); // Wait from 20 to 69 ms, or 100-400 ms
// Flash off
newdata=0;
Wire.beginTransmission(0x40); // Same as above
delay(random(30,50)); // Wait from 30 to 49 ms
jegillis
with the dev libraries? Im getting a compiling error with the original
ketch_feb07b.cpp: In function 'void Lightning()':
sketch_feb07b:185: error: redeclaration of 'int newdata'
sketch_feb07b:166: error: 'int newdata' previously declared here- cosmith71
Dammit. It's been a long day.
I fixed it. Recopy and try again, with the regular, non-dev libraries.
jegillis
- cosmith71
One more try for the night. This should flash all three channels.
#define BLUE_LED 9
#define RANet_OK 1
byte buffer_index;
byte buffer[128];
char buf[3];
byte RANetCRC;
byte BlueChannel=0;
Wire.begin();
RANetData[a]=0;
Wire.write(0);
Wire.write(0);
Wire.write(0xa1);
if (cable_present)
BlueChannel=100;
WhiteChannel=0;
BlueChannel=0;
WhiteChannel=0;
RANetCRC=0;
BlueChannel=0;
void Lightning()
int a=random(5);
int newdata=4095;
newdata=0;
jegillis
jegillis
Ok if I change the trigger to be sent on channel 2 only channel 2 flashes
No change on the effect still not ramping up.
- cosmith71
Hmmm. Give me a couple of days (one more 12 hour shift today and then some time off).
- cosmith71
Lets try this. Use the dev libraries.
On the RA:
On the receiver module:
Note that this one doesn't necessarily go to black. You should have (fast) flashes that return to the previous white channel values.
On the RA:
#define NUMBERS_8x16
#define FONT_8x8
#include <SoftwareSerial.h>
byte DaylightPWMValue=0; // For cloud code
boolean FireInTheHole=false; // True if trigger has been sent
byte TriggerChannel=1; // Dimming expansion channel to look for lightning trigger
byte Trigger=150; // Value sent to RANet Dimming module to trigger lightning strikes
byte x = 6;
byte y = 2;
byte t;
char text[7];
//static byte vtechmode=0;
// *********** CHANGE TEMP READOUT COLOR DEPENDENT ON CHILLER STATUS ***********
int TempColor; // Color for drawing temperature
boolean FanOn = ReefAngel.Relay.Status(Port8); // Get the status of the Chiller relay
if (FanOn)
TempColor = COLOR_RED; // Red text, too warm, chiller is on
if (!FanOn)
TempColor = COLOR_GREEN; // Green text, no chiller on
ReefAngel.LCD.DrawDate(6, 2);
ReefAngel.LCD.DrawLargeText(3,255,8,14,"Redneck Reefin!", Font8x8);
ReefAngel.LCD.DrawLargeText(3,255,8,55,"Jason & Sarah's", Font8x8);
ReefAngel.LCD.DrawLargeText(3,255,32,64,"Money Pit", Font8x8);
ReefAngel.LCD.DrawText(COLOR_RED,255, 6, 88, "--------------------");
ReefAngel.LCD.DrawText(COLOR_RED,255, 2, 93, "|");
ReefAngel.LCD.DrawText(COLOR_RED,255, 2, 103, "|");
ReefAngel.LCD.DrawText(COLOR_RED,255, 2, 113, "|");
ReefAngel.LCD.DrawText(COLOR_RED,255, 2, 123, "|");
ReefAngel.LCD.DrawText(COLOR_RED,255, 126, 93, "|");
ReefAngel.LCD.DrawText(COLOR_RED,255, 126, 103, "|");
ReefAngel.LCD.DrawText(COLOR_RED,255, 126, 113, "|");
ReefAngel.LCD.DrawText(COLOR_RED,255, 126, 123, "|");
ReefAngel.LCD.DrawLargeText(0,255,8,25,"TANK", Font8x8);
ConvertNumToString(text, ReefAngel.Params.Temp[T3_PROBE], 10);
ReefAngel.LCD.DrawLargeText(TempColor, 255, 42, 25, text, Font8x8);
ReefAngel.LCD.DrawLargeText(0,255,8,35,"HOOD", Font8x8);
ReefAngel.LCD.DrawLargeText(153, 255, 42, 35, text, Font8x8);
ReefAngel.LCD.DrawLargeText(0,255,8,45,"ROOM", Font8x8);
ReefAngel.LCD.DrawLargeText(66, 255, 42, 45, text, Font8x8);
ReefAngel.LCD.DrawText(0,255,100,25,"pH");
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 85, 35, text, Num8x16);
ReefAngel.LCD.DrawOutletBox(12, 75, TempRelay);
ReefAngel.LCD.Clear(255,46,96,70,104);
ReefAngel.LCD.Clear(255,106,96,132,104);
ReefAngel.LCD.DrawText(0,255,8,96, "White=");
ReefAngel.LCD.DrawText(197,255,46,96, ReefAngel.PWM.GetChannelValue(1));
//ReefAngel.PWM.GetDaylightValue()),
ReefAngel.LCD.DrawText(0,255,72,96, "Blue=");
ReefAngel.LCD.DrawText(3,255,106,96, ReefAngel.PWM.GetChannelValue(0));
//ReefAngel.PWM.GetActinicValue());
ReefAngel.AddRANet(); // Support for RANet wireless accessories
ReefAngel.FeedingModePorts = Port4Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit;
ReefAngel.LightsOnPorts = Port3Bit;
// Use T3 probe as temperature and overheat functions
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port7 );
ReefAngel.SingleATOLow( Port1 );
ReefAngel.WavemakerRandom( Port5,30,100 );
ReefAngel.WavemakerRandom( Port6,30,100 );
ReefAngel.StandardFan( Port8 );
// Cloud/lightning lighting control
ReefAngel.PWM.SetChannel( 0, PWMParabola(9,30,23,00,5,100,5) ); // Set actinic channel
DaylightPWMValue=PWMParabola(10,30,22,0,0,100,0);
CheckCloud(); // Check to see if it's time for a cloud/lightning
if (!FireInTheHole)
ReefAngel.PWM.SetChannel(1,DaylightPWMValue); // Whites are on channel 1
ReefAngel.PWM.SetChannel(2,DaylightPWMValue); // and channel 2
ReefAngel.Portal( "jegillis" );
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 4
#define Start_Cloud_After NumMins(12,00)
#define End_Cloud_Before NumMins(21,00)
// Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen resuls could happen.
// Add Random Lightning modes
#define Calm 0 // No lightning
#define Slow 1 // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 2 // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 3 // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 4 // Like Mega, but with more lightning
// Example: { Slow, Fast, Mega, Mega2 } to randomize all four modes.
// { Mega2 } for just Mega2. { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
byte LightningModes[] = {Mega};
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
static byte lightningMode=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue,5,180);
if (chooseLightning)
chooseLightning=false;
switch (lightningMode)
case Calm:
break;
case Mega:
// Lightning chance from beginning of cloud through the end. Chance increases with darkness of cloud.
// Send the trigger
WriteTrigger();
break;
case Mega2:
// Higher lightning chance from beginning of cloud through the end. Chance increases with darkness of cloud.
WriteTrigger();
break;
case Fast:
WriteTrigger();
break;
case Slow:
// Slow lightning for 5 seconds in the middle of the cloud. Suitable for slower ELN style drivers
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
DaylightPWMValue=0;
delay(1);
break;
default:
break;
cloudindex++;
if (cloudindex < numclouds)
ReefAngel.LCD.DrawText(0,255,85,110,"Length");
ReefAngel.LCD.DrawText(0,255,11,110,"Cloud");
ReefAngel.LCD.DrawText(0,255,51,110,"Storm");
int x=0;
else x=17;
else x=35;
if (lightningchance)
int x=0;
else x=57;
else x=75;
ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60)); // Write the minute of the next lightning to a custom variable for the Portal
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
void WriteTrigger()
FireInTheHole = true;
ReefAngel.RANetTrigger(1);
//ReefAngel.PWM.SetChannel(TriggerChannel, Trigger);
#define BLUE_LED 9
#define RANET_MAX_SIZE 68
#define RANet_OK 1
#define LIGHTNING 1 // Trigger value for lightning strike
#define TRIGGER 62 // Position in payload of trigger byte
byte buffer_index;
byte buffer[128];
char buf[3];
byte RANetCRC;
byte BlueChannel=0;
Wire.begin();
RANetData[a]=0;
Wire.write(0);
Wire.write(0);
Wire.write(0xa1);
if (cable_present)
BlueChannel=100;
WhiteChannel=0;
BlueChannel=0;
WhiteChannel=0;
RANetCRC=0;
for (int a=0;a<12;a=a+2) // Step through the 12 bytes of dimming data
byte newdata=(RANetData[18+a]); //LSB
byte newdata1=(RANetData[18+a+1]); //MSB
Wire.write(0x8+(4*(a/2))); // Channels 0 through 5
Wire.write(newdata); // Write LSB
Wire.write(newdata1); // Write MSB
BlueChannel=0;
if (RANetData[TRIGGER]==LIGHTNING) Lightning(); // Look for lightning trigger
RANetData[TRIGGER]=0; // Clear trigger byte.
void Lightning()
// Flash on
int newdata=4095;
// Flash off
Wire.write(RANetData[20]); // Return to previous value
Wire.write(RANetData[21]);
Wire.write(RANetData[22]); // Return to previous value
Wire.write(RANetData[23]);
jegillis
It's working!!
video to follow after I get my youtube app to listen to me
jegillis
- cosmith71
Awesome!
I still don't know what was wrong. Had to be something interfering with the trigger on channel 1. The new way is better anyway.
