Water level expansion
Ismaclst
Post by Ismaclst »
What is the max length of pipe and tubing you can have on the water level expansion? My tank is upstairs and my rodi water is in the basement. I was wanting to use the expansion to measure the water so I could turn a 24V valve on when it got low and off when it reached the desired height.
Re: Water level expansion
The pipe doesn't have that much range, but you may be able to get decent results with a long tubing if you keep it the temperature constant.
Roberto how about an RANet water level sensor...that would be freaking awesome :)
Or wait would it be possible to have RANet hub? This way you could just send/receive to any of the RA modules :)
